MSD CDI General Wiring Questions - JeepForum.com
post #1 of 7 Old 10-22-2013, 08:00 PM Thread Starter
Cashcrazy
1983 CJ7
I have been working on getting the most out of my 258. So far the ignition upgrades have been the best changes I have made to the Jeep. I really think the CDI box will be the icing on the cake. I would like to have a full understanding of the wiring for the CDI box. I will run through what I think I know. I borrowed the pictures from other Jeepforum threads.
Where the Duraspark uses orange and violet wires(top pic), the MSD uses the green & purple wires (bottom pic) connected to the MSD-8869 adapter (below).
Green Duraspark wire "replaced" by MSD Black wire.
Red Duraspark wire replaced by MSD Orange wire.
I am confused where the Duraspark gray wire is being replaced on the MSD wiring.
The black wire is "unused" due to the MSD being grounded to the battery??
Where exactly do I need to connect the small red wire on the MSD? I found another drawing showing it connected to the positive side of the horseshoe connector, but orange wire goes there. Do these get spliced?
Bypass the ballast resistor altogether with the MSD?
What difference will it make routing the heavy red MSD wire directly to the battery vs to starter relay?
Msd makes an extension cable for the distributor plug, a shielded version #8862, and a non shielded #8860. Is the shielded really needed?
I hope someone can make sense of what I am trying to get right in my brain. I have read several threads about people smoking their box by not wiring correctly. I do not want to tell that story.
1982 CJ7(sold), 1983 CJ7(sold), 1989 YJ(sold), 1983 CJ7 undergoing frame-off.
Cashcrazy is offline
post #2 of 7 Old 10-22-2013, 09:12 PM
WindKnot
1977 CJ7
Here's a link to MSD Ignitions, click on the Instructions tab and then the PDF; the instructions will download for you:
http://www.msdignition.com/Products/...n_Control.aspx
It really is a very simple project.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #3 of 7 Old 10-23-2013, 02:33 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The small red wire attaches to a switched 12V source. Most guys splice into the large Red w/white tracer wire somewhere between the firewall and the old factory ignition module.
Good luck,
Matt
Matt1981CJ7 is offline
post #4 of 7 Old 10-23-2013, 03:53 AM
keith460
Jeep. There's Only One
keith460's Avatar
Here's the MSD wiring version I used when I had the 6AL installed.
The gray wire is not used.
Black wire is not used, just make sure your distributor is grounded by the hold down clamp.
Red wire is the source that turns ON the MSD unit through your ignition switch.
I don't know if you need to Ballast Resistor in your application.
I have my heavy MSD red wire tapped onto the starter relay where the battery cable connects to it.
You only need to run a shielded wire if you plan on routing the wires of the MSD unit in the loom of the stock wiring. Shielded cable eliminates electronic 'noise' that may effect the signals to the MSD unit. If you mount your MSD box close or near the distributor, say passenger fender for I6 engine, then you don't need shielded cable.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 7 Old 10-23-2013, 06:46 AM
Matt1981CJ7
1981 CJ7
Here's the one I used, since I don't have a factory tach.
The only difference is, I spliced the little red wire into the harness where I mentioned earlier, instead of using the coil connector.
Matt
post #6 of 7 Old 10-23-2013, 07:27 AM Thread Starter
Cashcrazy
1983 CJ7
Thanks for all of the responses. Matt yours is super clean under the hood, looks great. I think I have it figured out. I am going to wait for it to arrive and then decide where I want to mount it. I can't wait to see the results.
post #7 of 7 Old 10-23-2013, 09:33 AM
WindKnot
1977 CJ7
This seems to be the most prevalent spot. It's close to where the wiring needs to go and away from heat. You can hide it anywhere there's good air circulation though. Just keep it away from heat.
WindKnot is offline
