MSD-6A Mounting Location Ideas? - JeepForum.com
post #1 of 18 Old 05-03-2009, 08:45 PM Thread Starter
JeepnBlake
I'm looking for some idea's on where to mount my MSD box, i was thinking fenderwell, but my fenders are fiberglass, and i'm not sure that would work out too well. I was also thinking mounting it up above the heater box, in the cab, would it get too hot up there?
Where are you guys mounting yours?
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #2 of 18 Old 05-03-2009, 09:08 PM
scottymac62
1979 CJ7
I mounted mine behind the firewall. You can buy an extension line for the magnetic pickup trigger at summit.
http://store.summitracing.com/partde...5&autoview=sku
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #3 of 18 Old 05-03-2009, 09:28 PM Thread Starter
JeepnBlake
i have that little guy from summit, you wouldn't happen to have a picture would you?
-Blake-
Build Thread:
Dad's Build Thread:
post #4 of 18 Old 05-03-2009, 09:43 PM
scottymac62
1979 CJ7
Sure .
post #5 of 18 Old 05-03-2009, 11:25 PM
kstopp
1993 XJ Cherokee
I mounted mine right below the fuse block, but I had previously moved my ebrake which might interfere normally. I didn't end up needing the extension either
kstopp is offline
post #6 of 18 Old 05-04-2009, 03:02 AM
GPER
1979 CJ7
I used an extra nuts so I didn't have to mess with the bolts.
Next to the glove box.
GPER is offline
post #7 of 18 Old 05-04-2009, 06:12 AM
Happy Joe
I mounted one on the firewall above the 258 (a PITA), a second Jeep got one mounted to the passenger side fender.
Enjoy!
'06 TJ Rubicon; seemed like a good idea at the time; had many CJs...
Happy Joe is offline
post #8 of 18 Old 05-04-2009, 10:37 AM
00bluedak
mine is mounted on the passenger side fender below the battery where the stock jack assembly was.
00bluedak is offline
post #9 of 18 Old 05-04-2009, 11:03 AM
JeepHammer
Running On Empty...
1973 CJ5
I'm with GPER, mine is mounted behind the dash panel.
If the water gets that high, I have other problems!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #10 of 18 Old 05-04-2009, 11:09 AM Thread Starter
JeepnBlake
Does anyone have a picture of their box mounted behind the dash panel?
right now i'm undecided between top of passenger fender, or behind the dash some where
I do like the way yours is sitting GPER, except i still have speakers in my dash, so i don't think that will work as well.
-Blake-
Build Thread:
Dad's Build Thread:
post #11 of 18 Old 05-04-2009, 12:27 PM
GP_Pete
GP_Pete's Avatar
mounted on the top side of the passenger fender. It fits nicely since the CJ hood is fairly tall.
GP_Pete is offline
post #12 of 18 Old 05-04-2009, 03:00 PM
motiv8ya
1979 CJ7
Passenger fender mount.....
http://i487.photobucket.com/albums/r...a/101_2545.jpg
motiv8ya is offline
post #13 of 18 Old 05-04-2009, 03:45 PM
Mike Romain
There are no issues with a glass fender install if you just run a dedicated ground tag. Not even sure if it even needs a ground.
Mike
Mike Romain is offline
post #14 of 18 Old 05-04-2009, 04:16 PM
JeepHammer
Running On Empty...
1973 CJ5
Don't need a ground since the module has the large 'Black' wire to ground it... And the case DOES NOT need to be grounded.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #15 of 18 Old 05-04-2009, 05:55 PM
GPER
1979 CJ7
I don't see any problems with it on a glass fender. I have a one gallon air tank mounted to my fender for years now without problems.
GPER is offline
Mounting location suggestions for secondary heaters? texasimport Jeep CJ Forum 13 09-01-2009 01:55 PM
Gas Tank Mounting Location Hybrid Jeep Jeep CJ Forum 4 10-13-2008 08:01 AM
Remote Winch Solenoid Mounting Location Question Mud Machine Jeep CJ Forum 2 07-12-2005 05:20 PM
Negative Battery Terminal Mounting Location certifiablejeep Jeep CJ Forum 7 03-03-2004 12:38 PM
MSD ignition mounting location possum398 Jeep CJ Forum 3 08-13-2003 12:32 PM
