msd 6a diagram - JeepForum.com
post #1 of 5 Old 04-19-2008, 05:03 PM Thread Starter
stlouis400ex
msd 6a diagram
I have this diagram for the duraspark but does anybody have a diagram for a msd 6a with a painless wiring harnes setup? or is there any body who could help me throught It? I am in a tuff spot and tryed many different configurations..
Thanks
Trey
stlouis400ex is offline
post #2 of 5 Old 04-19-2008, 08:08 PM Thread Starter
stlouis400ex
can anybody help me?
post #3 of 5 Old 04-19-2008, 09:32 PM
JeepHammer
Running On Empty...
1973 CJ5
OK, Try this...
The 'Ignition' wire from your 'Painless' kit should connect to the small red wire as shown...
*IF* you don't get ignition when cranking,
And it's possible depending on the swich you have,
Add a wire between the small Red & the 'I' terminal on the starter relay...
That will power the MSD module while you are cranking.
Not all vehicles need it, just see if your harness is going to power the 'Ignition' wire when the key switch is in the 'Crank' position...
If it does, you won't need the extra wire.
If it DOES NOT, you will have to add the wire.
DON'T BE CHEAP!
BUY the MSD adaptor p/n 8869,
http://store.summitracing.com/partde...5&autoview=sku
It makes the distributor a 'Plug In' to the MSD hardware, and it keeps the magnetic trigger polarity correct for the module.
If you are really tight and don't want to spend the extra money, take a CLOSE LOOK at the wire color coding between the module and distributor.
The diagram IS CORRECT... And 90% of the people who splice get it wrong!
And buy a new coil connector for the coil you are using from NAPA or somewhere.
The part numbers are listed on the diagram.
This will make your install a 'Snap' and make it look so much neater...
If you need more cable to reach between the MSD and the distributor adapter, try MSD p/n 8862 for 6' of extra reach.
KEEP THIS WIRE AWAY FROM SPARK PLUG OR COIL WIRES!
If you let it get too close to high energy wires, you will get false triggers!
Notice MSD put the trigger wires on the other end away from everything else... There is a reason for that!
If this don't help you, no one can!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #4 of 5 Old 04-20-2008, 07:44 AM Thread Starter
stlouis400ex
Originally Posted by JeepHammer View Post
OK, Try this...
DON'T BE CHEAP!
WOW!! thanks that is everything I could ask for And is how I have my stuff setup. I am using a new msd tfi blaster coil. I think my problem is I am grounding the msd box to the body not the neg on the battery. I will try the I term If I am still not getting ingtion. thanks.. one other thing I looked over was cutiing the little red wire inside the msd box to set it up for a inline six.
Thanks again
Trey
post #5 of 5 Old 04-20-2008, 10:26 AM Thread Starter
stlouis400ex
do you still strongly suggest grounding the black wire on the dizzy?
Wiring diagram for 77 CJ5 spankyway Jeep CJ Forum 11 08-16-2007 09:27 PM
Can someone help me with a wiring diagram? smithgrow Jeep CJ Forum 1 03-25-2007 03:29 PM
vaccum diagram 79 304 dizz Jeep CJ Forum 4 03-14-2007 08:32 AM
Wiring Diagram Dimension4 Jeep CJ Forum 7 01-30-2007 03:01 PM
304 vac diagram rmballou Jeep CJ Forum 2 03-23-2006 09:49 PM
