moving and carb question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > moving and carb question
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineThe Boss is away but Erin is here to STAY with a F.Y.S. SaFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-07-2015, 08:49 AM   #1
neal90
1982 CJ7
I will be moving in the next few weeks from NC (very low elevation) to El Paso TX VERY high elevation. My question is how much retuning will I have to do to the jeeps carb. It is all stock except the carb. I replaced it with a MC 2100, might actually be a 2200. Iím just wandering if everything is going to be all outa whack when I move.
neal90 is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 08:52 AM   #2
mastercraftka
mastercraftka's Avatar
Whats the actual elevation change? I wouldn't guess it would affect it that much.
1984 CJ 7
1948 CJ 2A
1982 CJ 7
1981 CJ 7
mastercraftka is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 09:00 AM   #3
jeepwhore
Hair puller xtraordinaire
jeepwhore's Avatar
x2. And what jets are in your carb right now?
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 09:03 AM   #4
neal90
1982 CJ7
Its well over 2000 feet higher. I can tell you i have lived in el paso in the past and if you go running you can tell a big change in how you fell when running. Also not sure what jets are in it right now. It was one of the ebay carb kits. I havent change anything from the day i got it except the 2 little screws in the front to tune it.
Unread 04-07-2015, 09:05 AM   #5
j33ping
j33ping is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 09:09 AM   #6
neal90
1982 CJ7
Sounds like I should be good. The elivation in el paso is 3800 feet. I understand from you posted the jets should be good. Do you think it will need any extra tunning??
Unread 04-07-2015, 10:51 AM   #7
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
A long-time rule-of-thumb for altitude jetting any carb is to reduce one jet size for every 2000 feet of elevation. This has proved spot on for my Weber and Q-jet carbs.
You should also lean out your idle mixture a tad and bump your initial advance a few degrees.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 04-07-2015, 11:36 AM   #8
j33ping
Unread 04-07-2015, 11:51 AM   #9
Matt1981CJ7
1981 CJ7
Originally Posted by j33ping View Post
Matt, fill me in, why are you suggesting changing the initial advance a couple degrees?
Cylinder pressure is lower at higher elevations due to less atmospheric pressure. Therefore the burn is slower and needs to be lit sooner.
I run 15-16* initial advance on my 360, per the FSM high elevation instructions, without any pinging.
Matt
