Mounting hardtop to fiberglass tub - JeepForum.com
post #1 of 14 Old 10-11-2007, 04:28 PM Thread Starter
bill in the hil
1980 CJ7
I Have a fiberglass jeep and the hard top was screwed onto the tub and windshield and I am looking for better set-up. It has a small lip on tub but noway to attach nuts under it like on steel tubs. Thought maybe there was a nice kit or clamp system I could install and not have to just run screws down into body and look like crap when top is off. Thanks for taking time to look.
bill in the hil is offline
post #2 of 14 Old 10-11-2007, 06:02 PM
pwhit
http://www.quadratec.com/products/13122_04.htm
these might work
84 CJ7 258 I6, T-4, D300, 2.5" BDS, 35x12.5 MT's, Fiberglass body (SOLD)
73 J4000 360, Auto, Quadratrac ...... work in progress
pwhit is offline
post #3 of 14 Old 10-11-2007, 06:18 PM Thread Starter
bill in the hil
1980 CJ7
Thanks. Yeah they might. I would hate to spend that much and they wont. I was hoping someone ran into same problem and had a good remedy. Do you run a hardtop on your's?
post #4 of 14 Old 10-11-2007, 07:50 PM
Jimthejeepman1
1978 CJ7
Just to let you know, those dont work..........I have the same problem and ordered those but they dont open far enough to clamp down where you need to clamp. I thought they would work based on the picture but they told me the pic was just general not exactly to scale.
Jimthejeepman1 is offline
post #5 of 14 Old 10-11-2007, 08:04 PM Thread Starter
bill in the hil
1980 CJ7
Right on Jim!! I appreciate the heads up. You may have saved me $60. I am probably going to go out this weekend and throw the top back on(Winter is damn near here).
I guess i will just have to get creative and come up with my own mounting system. I was thinking about a plate with threaded inserts I could recess in tub. Maybe bust out the powdercoater and pretty it up. Have to see if someone has any better ideas. Got to do something. Bikini top weather is a thing of the past.
Maybe I should move south and get out of the hills. Thanks again.
post #6 of 14 Old 10-11-2007, 08:04 PM
pwhit
I have a hardtop but it is screwed into the fiberglass tub. I'm looking to get rid of mine and go w/ a soft top. I have heard of people installing nutserts into the top rails and then putting in bolts. That may be an option.
pwhit is offline
post #7 of 14 Old 10-11-2007, 08:09 PM
pwhit
You also might be able to go to a truck camper store and get some type of clamp that might work. Just some thoughts.
pwhit is offline
post #8 of 14 Old 10-11-2007, 08:09 PM Thread Starter
bill in the hil
1980 CJ7
Thought about nutserts. Just not sure if they could pull back out of body. Hate for that to happen. Not as much as dude behind me would. I will have to check more ito them. That is why I was thinking about mounting something like them to a thin strip I could attach down edge. Will have to think more about this. I got a big shop full of resources. I will come up with something.
post #9 of 14 Old 10-11-2007, 08:15 PM
Jimthejeepman1
1978 CJ7
I got creative and used three c clamps on each side welded to a thin strip of steel on top and bottom........I just line the strips up on the top and bottom lip and crank em down snug, and it has worked this far with no probs......
post #10 of 14 Old 10-11-2007, 08:20 PM Thread Starter
bill in the hil
1980 CJ7
Now were talking. I like that. Simple and effective. Now I have direction. Thanks again Jim
post #11 of 14 Old 10-11-2007, 08:23 PM
Jimthejeepman1
1978 CJ7
no prob
post #12 of 14 Old 10-11-2007, 09:47 PM
OldSailor
1977 CJ7
Go to a place that sells camper shells (tops). They sell clamps that are made to hold a camper top onto a pickup bed. You should be able to find some clamps that will hold the hard top onto your fiberclass body.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
post #13 of 14 Old 11-21-2011, 06:37 PM
scso81
1980 CJ7
Has anyone that has mounted a fiberglass top to a fiberglass cj7 tub have any pictures they can share of how they did it? I would love to mount my hard top on for the winter and use my fiberglass doors to boot. I think that combo will keep it toasty in there.
My sweet 1980 CJ7 continuing build.
scso81 is offline
post #14 of 14 Old 11-21-2011, 09:03 PM
cjjon7
1983 CJ7
Toasty??? Never! Just above freezing, yes, so you can wipe the windows off!
cjjon7 is offline
Fiberglass windshield and bar mounting StewartCJ7 Jeep CJ Forum 1 10-15-2009 11:22 AM
Mounting E-brake pedal assembly to fiberglass body chet44 Jeep CJ Forum 4 10-12-2009 11:27 AM
Fiberglass body mounting questions Arcticcat843 Jeep CJ Forum 6 06-04-2009 06:49 PM
CJ5 Acme Hardtop on a Fiberglass Body jschade1 Jeep CJ Forum 7 10-22-2008 05:53 PM
mounting fiberglass body oreo_n2 Jeep CJ Forum 2 10-02-2003 04:55 AM
