motorcraft ignition help please! - JeepForum.com
post #1 of 22 Old 11-15-2011, 01:39 PM Thread Starter
TMoore83
1976 CJ7
Hey everybody.
dunno whats going on with my rig here, but i need some second or third opinions...304, motorcraft ignition, ran awesome yesterday.
Took the rig for a drive yesterday to burn some gas up, she ran fine.
I dropped the gas tank to replace the sending unit gasket, and like the dunce that i've been lately, i left the ignition on over night.
I go to crank her up the next day, dead battery and....and NO SPARK. I'm getting fuel, plenty of air.
I've replaced ignition modules several times on my CJs, so i went with that first. cheap and easy. and NOTHING STILL
I had an old coil from my I6 that i slapped on there and still nothing.
The distributor is fairly new, less than 2 years old and really clean.
I'm getting power to the module, and with my test light, the GREEN wire on the module is lit up when the ignition is on...
What should the ORANGE and VIOLET wires been doing during all this?
really at a bit of a loss here.....i've killed my battery twice today cranking her, gonna let it charge, have a few beers and try again. any ideas?
Thanks for reading!
TMoore83 is offline
post #2 of 22 Old 11-15-2011, 04:12 PM
gosupes
The orange and violet wires are trigger wires. You have voltage at the coil?
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #3 of 22 Old 11-15-2011, 05:20 PM
BagusJeep
1981 CJ7
You need to dig out a test light and Jeephammer's test procedure, which you can find with the Search facility, and go through each part of the system until you diagnose what is wrong.
I used it and within 5 minutes discovered a short at a 30 year old plug.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #4 of 22 Old 11-16-2011, 06:01 AM
JeepHammer
Running On Empty...
1973 CJ5
One More Time,
You would think they would make this a 'Sticky' by now...
1. Get yourself a test light with a bulb.
Looks like an ice pick with a bulb in the handle and a wire coming out of the handle.
Around $6 at the parts stores.
DO NOT GET THE LED VERSION.
2. Hook Test light WIRE to your battery NEGATIVE terminal.
Probe the Positive terminal to see if the test light is working.
3. DISCONNECT your coil connector from the ignition coil.
4. Probe the 'Red' wire terminal in the coil connector (Disconnected from the coil).
Turn the key switch to the 'Run' position, and see if you get a 'Light' at the tester.
This will tell you if the Ignition fuse, Ignition Switch, Factory Tach and all those little connectors under the dash are working,
And if that power is getting out to the ignition coil.
*IF*...
You do NOT get a light at the coil connector 'Red' terminal, then you have an issue INSIDE the Jeep, or with the fire wall connector, or resistor wire.
5. GET ANYTHING YOU DON'T WANT PINCHED, SMASHED, CUT OFF OR OTHERWISE DAMAGED OUT OF ROTATING PARTS OF THE ENGINE.
6. Have someone CRANK the engine (Key Switch to 'Start' position) and probe that same 'Red' wire terminal while cranking the engine.
You should get a 'Light' at the tester.
*IF*... You do NOT get that light when cranking,
Then you have an issue with the 'Red' wire on the small terminal of the starter relay marked 'I'.
That wire connected to the 'I' terminal on the starter relay goes over to the ignition coil 'Red' wire terminal to supply increased voltage to the coil while cranking.
Now you have Tested, and hopefully VERIFIED the power circuits to the ignition coil.
7. Move the tester wire to the POSITIVE (+) battery terminal and clip it on there.
Touch the Negative battery terminal to verify the tester is working.
8. PROBE the COIL CONNECTOR 'Green' wire terminal.
You should get a 'Light' showing the electrical 'Ground' path to the module, and... ->Through->... the module is working.
The coil electrically 'Grounds' by passing through a switch in the module.
If the 'Green' wire circuit is broken, corrosion, broken wire, whatever,
The coil can't 'Ground', and the module can't switch the coil 'On' and 'Off' to make it fire the plugs.
You SHOULD get a bright 'LIGHT' when you probe the 'Green' wire terminal.
*IF* you do NOT get a 'Light' then either the 'Green' wire circuit between coil connector and module is broken,
Or the 'Black' wire from module to distributor housing is broken,
Or the distributor is no longer making ELECTRICAL contact with the engine block.
(Mechanical Contact and Electrical Contact are two entirely different things)
9. Pull in anything you don't want mangled by the engine when it cranks,
And crank the engine while probing the 'Green' wire at the coil connector.
If you get a 'Flashing' light, then it's probably the coil, coil wire, distributor cap, rotor that isn't working correctly since a flashing light means the ignition module is trying to fire the ignition coil like 'Normal'...
If you DO NOT get a flashing light at the 'Green' wire terminal while cranking.
That means the ignition MODULE is not firing.
You need to find out why...
The next tests work with the module, mounted low on the back side of the DRIVES fender, under he washer tank on '78 to '86 Jeeps.
It's usually easier to work on the harness if you unbolt the module and raise it up as far as you can.
10. Connect the tester to battery NEGATIVE terminal, touch the Positive post to confirm the tester is working.
11. Unplug the TWO WIRE connector going to the module, The module side of the wiring will be 'Red' and 'White'.
You need to test the HARNESS SIDE, which will be a large (10 Ga.) 'Red' and a smaller 'Blue' wire.
Start with the smaller 'Blue' wire on the harness side of the connector,
See if you get a 'Light' when cranking the engine.
Don't worry about power to this one with the key switch in the 'Run' position, it shouldn't be 'Hot' when the key switch is in the 'Run' position, Just when cranking the engine.
If you get a 'Light' when cranking the engine, this power feed to the module is working.
12. Now test the larger 'Red' wire.
This terminal should have power when the key switch is in the 'Run' position, and will sometimes show 'Hot' when the engine is cranking, but that doesn't matter,
Just the key switch in the 'RUN' position is all we are looking for at this time.
*IF*... You got power at the coil in the 'Run' position,
And you DO NOT have power at this terminal in the run position,
Then you have a problem with the 'Splice' between the fire wall connector and where the wire splits into 3 wires (Called a 'Splice') in the harness,
If you found power when and were you needed it,
Then RECONNECT the two wire connector and move on.
13. UNPLUG the 4 wire connector at the module.
Connect your test light to the battery POSITIVE, we are testing the 'Black' wire, HARNESS SIDE.
Probe the black wire, Harness Side, and see if you get a strong, bright 'Light'.
This will confirm your module is getting electrical 'Ground' through the distributor.
That 'Black' wire goes to the distributor and 'Grounds' through the distributor housing.
14. Make up a 'Jumper' wire, just strip the ends of a wire,
Connect one end to the battery NEGATIVE, the other end to the COIL CONNECTOR 'GREEN' terminal.
Then probe the 'Green' wire in the HARNESS side of the 4 wire connector.
You should get a strong 'Bright' light. If you do NOT get a 'Light' then the 'Green' wire between coil and connector at the module is broken somewhere.
From this point forward, you will need a 'Multi-Meter' that is capable of testing for resistance, that means it has an 'Ohms' reading.
IF YOU HAVE A COMPUTER CONTROLLED IGNITION ('83 to '86), SKIP #15 since there won't be a 'Violet' wire in the harness side of the module 4 wire plug.
Move directly to #16 and test the distributor it's self if you don't have a Violet wire in the HARNESS side of the 4 wire module plug.
15. Set your Multi-Meter for 1,000 Ohms, and probe the 'Orange' and 'Violet' wires at the 4 wire connector, harness side.
You should see a reading of 400 to 800 Ohms, with about 625 Ohms being 'Normal' or 'Optimal'.
If you DO NOT get a reading of 400 to 800 Ohms, then you will have to move to the next test.
16. Unplug the distributor from the harness,
Test the DISTRIBUTOR SIDE of the connector, male plugs, you are testing the two running PARALLEL TO EACH OTHER ('Orange' & 'Violet' or 'Black' with 'Orange' stripe and 'Black' with 'Violet' Stripe on some distributors).
Again, you are looking for a reading of 400 to 800 Ohms, with around 625 being 'Nominal'...
*IF*... You DO NOT get the specified reading, the 'Stator' or 'Trigger' winding in the distributor is shot.
*IF*... You DO get the 'Nominal' reading at the distributor, but DID NOT at the module 4 wire plug,
Then you have a wiring problem between the distributor and the module connectors.
Testing the module...
Since there isn't any practical way to test the module other than replacing it,
I suggest you take the module to one of the parts stores and have them test it on the bench.
Since many of the stores DO NOT have properly trained personnel, I would suggest you take it to 3 or 4 of the stores, get a consensus on it's function.
A KNOWN working module is always a good thing to have, but you have to test that module while the vehicle is working, instead of waiting until the vehicle has stopped working since you won't know if your 'Test' module,
Or even a 'New' discount store module is working when you put it in...
Many of these 'Import' or 'China' modules don't work right out of the box, so you can't really rely on a 'New' module to give you a definitive answer.
This SHOULD give you a quick, easy way to find out at least WHERE the issue lays...
The Coil Connector Power test will let you know if the issue is on the firewall side of the coil,
Or in the engine harness it's self.
The module power test will confirm if you are getting power to the module while cranking, and if the 'Start' circuit is powering up like it's supposed to.
The coil ground test will let you know very quickly if the 'Ground Path' is the issue or not.
The Ohms test at the distributor and 4 wire plug let you know if the trigger is working in the distributor,
DO NOT forget to plug in the distributor, module and coil before you go cranking with a new module!
(Ask me how I know that one! )
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #5 of 22 Old 01-15-2014, 03:50 PM Thread Starter
TMoore83
1976 CJ7
son of a *****!....never replied to this since Jeephammer laid the knowledge down....my problem their turned out to be a BAD NEW MODULE....bought another one and she fired right up....fluke shiz........
So here i am two years later, i leave the key in the 'ON' position overnight....no start the next day. Burnt module...lifetime warranty....easy, right? I replace the module, STILL NO START. I check the fuses...the Ignition coil fuse is broken and the plastic is melted. Replace that....NO START STILL.
I bought another module from a different store just to make sure....STILL NO START
I'm getting power to the + side of the coil when the key is ON. When I hook the the test light to the POSITIVE on the battery and GREEN wire on the coil with the Ignition OFF I get a low light. With the ignition ON and battery positive to negative/GREEN coil, NO LIGHT.
Where do i go from here?
I tried another older coil i had sitting around, no start...
I'm thinking a new coil could be the next move.
I'm thinking very much about just going HEI on this thing....it worked so well for my old 258.....
Thanks so much for reading.
Tim
TMoore83 is offline
post #6 of 22 Old 01-15-2014, 04:36 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'm curious why you keep leaving the key in the ON position? I always pull my key out when I shut my engine down. ALWAYS!!
On the bright side, you have the testing procedure spelled out for you just above your last post. I highly recommend going step by step thru the procedure before throwing more parts at it.
Good luck, and let us know what you find.
Matt
Matt1981CJ7 is online now
post #7 of 22 Old 01-15-2014, 04:59 PM Thread Starter
TMoore83
1976 CJ7
Matt
my rig doesn't need a key.....so once every couple o' years it just happens...usually an easy fix....this time is a lil silly. I haven't been able to check it while its cranking, but....still sorta stuck with the results i listed above....
TMoore83 is offline
post #8 of 22 Old 01-15-2014, 05:02 PM
Matt1981CJ7
1981 CJ7
So, at what step of Aaron's test procedure are you stuck?
Matt
post #9 of 22 Old 01-15-2014, 05:14 PM Thread Starter
TMoore83
1976 CJ7
HERE:
" *IF* you do NOT get a 'Light' then either the 'Green' wire circuit between coil connector and module is broken,
(Mechanical Contact and Electrical Contact are two entirely different things) "
I get a light at the GREEN/- on the coil with ignition OFF, but NO LIGHT WITH THE IGNITION ON. I haven't had a helper to crank it while I look though....is it only suppose flash when i crank it?
TMoore83 is offline
post #10 of 22 Old 01-16-2014, 04:20 AM
86cj74.2L
86cj74.2L's Avatar
Generally when the ignition is left on both the coil and module are fried and both replaced together.
I would kind of think, like sort of anyway, replacing the coil and module together.
I got tired of all that duraspark crap and put the MSD6 on it I had in my Daytona. I then took that fried duraspark module and followed JH's and Johns instructions on gutting it and making a stealth HEI.
86cj74.2L is offline
post #11 of 22 Old 01-16-2014, 10:25 AM Thread Starter
TMoore83
1976 CJ7
Just replaced the coil......still no start......gettin kinda frustrated over here.
TMoore83 is offline
post #12 of 22 Old 01-16-2014, 10:44 AM
Matt1981CJ7
1981 CJ7
You really need to test the ignition control module.
If you can't find a helper, you can purchase a remote starter switch at virtually any auto parts store. Like this one.
Good luck,
Matt
post #13 of 22 Old 01-16-2014, 10:52 AM Thread Starter
TMoore83
1976 CJ7
I've got two brand new modules and I had one tested at the store, it passed.
I'm getting my buddy to do some cranking so I can investigate further....
TMoore83 is offline
post #14 of 22 Old 01-16-2014, 10:55 AM
Grumpy_one
1976 CJ5
(subscribed)
Grumpy_one is offline
post #15 of 22 Old 01-16-2014, 04:40 PM Thread Starter
TMoore83
1976 CJ7
so with the test light on the POSITIVE battery terminal and on the GREEN coil wire....no flash no light when cranking. With the ignition off, i get a light....
so ima go swap the module one more time just for the hell of it and see what's up. This is a weird one indeed.
TMoore83 is offline
John Strenk's Ignition Tilt Wheel Ignition Lock Replacement From78To83 Jeep CJ Forum 3 05-31-2011 12:40 PM
burned out 2nd Motorcraft ignition module in a month!! skidplate77 Jeep CJ Forum 11 10-28-2009 07:23 AM
changing from gm points dist to motorcraft, motorcraft has wrong gear help!!! baystrucksalvag Jeep CJ Forum 3 07-23-2008 07:55 PM
Motorcraft meltdown-ignition modual!!! only in a jeep cj Jeep CJ Forum 4 10-07-2003 08:44 AM
Prestolite to Motorcraft ignition system mrjoshuaw Jeep CJ Forum 1 08-03-2002 11:36 AM
