Motorcraft 2150 power valve and jet size - JeepForum.com
post #1 of 19 Old 08-22-2013, 11:14 PM Thread Starter
drespecki
1983 CJ7
Motorcraft power valve and jet size most are running?
Hi...Need some info on who is running what with their motorcraft 2100/2150 carb on the 258. I am at 2500 feet and run up from 2500 to 8000 once in a while but am at 2500 85% of the time... What is the best power valve size and jet size for my area? (Tucson AZ)
It only hurts while you're breathing..
drespecki is offline
post #2 of 19 Old 09-17-2013, 11:57 AM Thread Starter
drespecki
1983 CJ7
Anyone?
post #3 of 19 Old 09-18-2013, 10:23 PM Thread Starter
drespecki
1983 CJ7
Have the carb off and see that I have #47 jets and a 7.5 power valve.. Should I try #46 jets and a 6.5 power valve at my altitude of 2500+ feet?
post #4 of 19 Old 09-19-2013, 11:43 AM
Jon In Tucson
Jon In Tucson's Avatar
1983 CJ5
Dr.
Not on a Jeep, but about a million years ago, my son and I had a '51 Chevy 1/2 ton with a newer GM 235ci. The carb was a 2 bbl Holley, and I believe the jets were 46's. Too much water under the bridge to remember the power valve. How do the spark plugs look with the combo you're running now? Do you need to pass emissions? Or just wanting to improve performance? No matter what you do tuning wise for 2500', up on the mountain it will run rich. I would tune towards where you do the majority of your driving, in this case the desert floor. God bless.
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline
post #5 of 19 Old 09-19-2013, 02:48 PM
wm69
Are you having any problem with it? I'm running 47's in one Jeep, 46's in the other, and honestly I can't really tell a difference. I'm around Memphis TN, whatever elevation that is........
wm69 is offline
post #6 of 19 Old 09-19-2013, 07:26 PM
CrazyHorse6
1979 CJ7
What venturi? Hopefully 1.08. What's your vacuum pulling? You want a power valve which is rated for half of the inches of vacuum at sea level I believe- mine pulls 21" of vacuum so I run a 10. For the jets, start at 47 and work down as needed.
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #7 of 19 Old 09-19-2013, 11:15 PM Thread Starter
drespecki
1983 CJ7
Back for a few minutes....Seems that I was around 17 or 18 on the manifold vacuum but did not drive it to get the true reading (think there was something else I needed to do to get the proper PV size?)..Just pulled out the 47's and am putting in 46's and a 6.5 pv to see how it responds. Might opt for a Weber 38/38 or a 32/36. If I was rolling in dough, the Howell FI would be the ticket but alas, I am a bit shy of that price range.
Am down right now, rolling monstaliner this week and she is all apart for a few days.
post #8 of 19 Old 09-20-2013, 08:00 AM
jeepwhore
Originally Posted by CrazyHorse6 View Post
.....You want a power valve which is rated for half of the inches of vacuum.....
That's a good starting point but to really nail down which PV you should have you need to monitor your A/F ratio with a wide band O2 sensor. Most people don't but that is the best way to really dial it in.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #9 of 19 Old 09-20-2013, 11:36 AM
wm69
I've had a 32/36, and like the MC2100 much better. The 32/36 did perform better than the MC2100, but not by much, but the main reason I like the MC is once you get it dialed in, it stays dialed in for a long time.
I had to monkey with my Weber ALL the time to keep it running right. With the MC, I bolted it on, spent a little time on the choke and mix adjustment screws, and haven't had to mess with it for a lonng time.
wm69 is offline
post #10 of 19 Old 09-30-2013, 10:09 AM Thread Starter
drespecki
1983 CJ7
Well, the monstaliner will be finished this week, need to put the 2150 back on and guess I need to pick a power valve..... 6.5 7.5 or 8.5
Anymore opinions on which one to go with on my worn out old 258?
Thanks for all the input, I am trying to absorb it!
post #11 of 19 Old 09-30-2013, 11:15 AM
scrapman
You will have to put on the mc2100, and find out what your PTC vacuum is.
Find a flat, long road and hook up your vacuum gauge with a long enough line to get it in the cab with you. Hold a steady speed somewhere between 45-55mph, and read what vacuum you are at. This is your Part Throttle Cruise vacuum. Your power valve should be about 2 below this number.
If I remember correctly, my PTC was 10, so I went with a 7.5 power valve.
scrapman is offline
post #12 of 19 Old 09-30-2013, 11:19 AM Thread Starter
drespecki
1983 CJ7
What was your in park idle vacuum? (i have an automatic) I need a rough gauge to go by to put one in so I can go down the road and do that vacuum test... Mine was about 18hg in park at idle..
post #13 of 19 Old 09-30-2013, 01:46 PM
scrapman
Mine was about 18.5 in neutral (standard).
scrapman is offline
post #14 of 19 Old 10-01-2013, 06:33 PM Thread Starter
drespecki
1983 CJ7
Would regular manifold vacuum be okay to do the test with or do I need carb baseplate vacuum closer to where the power valve is for a more accurate reading?
post #15 of 19 Old 10-02-2013, 07:48 AM
scrapman
I went with regular manifold vacuum.
Not because it is the best reading, but because I didn't know if there would be a difference in the reading closer to the carb base plate.
scrapman is offline
