motorcraft 2150 help - coming off idle - JeepForum.com
post #1 of 6 Old 07-08-2008, 08:42 PM Thread Starter
Jermy01
1978 CJ7
hey guys. so i just got my rebuilt motor into my jeep. Motor runs good, but the carb definately needs a little help.
my biggest part is when i am coming off idle, especially if i just barely push the pedal, it cuts out. i rebuilt the carb when i was rebuilding the motor, but if i remember correctly it was doing that before i started the rebuild. the accelerator pump is working fine, and i tried adjusting the throw for the accelerator pump, still did the same thing. It does it whether its hot or cold. i did notice my carb is missing the dashpot on the throttle positioner, but i thought this was only for coming down to idle (which it does bog a little there too)
any help would be great. thanks
-Jeremy
1978 CJ7, front and rear locker, 31'' BFG mud Terrain, superior axles. RE 2.5" lift. 304 V8. Warn M8000.
Jermy01 is offline
post #2 of 6 Old 07-09-2008, 12:48 PM Thread Starter
Jermy01
1978 CJ7
anyone???????
-Jeremy
Jermy01 is offline
post #3 of 6 Old 07-09-2008, 12:54 PM
JeepHammer
Running On Empty...
1973 CJ5
It's your accelerator pump adjustment.
You just described a classic case of accelerator pump linkage problems.
You have to make sure the accelerator pump throws fuel the INSTANT the throttle shaft starts to move when you are adjusting!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #4 of 6 Old 07-09-2008, 04:14 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Might double check the umbrella seal in the pump housing. If it wasn't installed properly, it can cause a bog due to not sealing properly. Also, insure the diaphragm isn't in back wards.
jeepdaddy2000 is offline
post #5 of 6 Old 07-09-2008, 05:42 PM Thread Starter
Jermy01
1978 CJ7
i have played with the accelerator pump and it does squirt a shot as soon as i touch the throttle, will take it apart tho and make sure everything looks good in there
-Jeremy
Jermy01 is offline
post #6 of 6 Old 07-09-2008, 10:39 PM
coas
Beside adjusting the acc pump you might need a new diaphragm.
Should look like the left one, if it's distort, like the one on the right, the amount of fuel in a shot is too low:
(30 years old OEM diaphragm vs after market junk)
84 CJ7 , Dana 44 rear D30 front, 258, 4.0 head, MPFI, e-fans, T176, Dana 300, 31x10.5x15 and Mustang hydroboost.
My esnips folders:
coas is offline
Motorcraft 2150 carb ID? Mike1084 Jeep CJ Forum 6 06-25-2009 11:44 AM
Motorcraft 2150 carb b1gbee Jeep CJ Forum 1 03-26-2009 06:14 PM
Motorcraft 2150 specops72 Jeep CJ Forum 12 11-15-2008 10:57 PM
Motorcraft 2150 DFA Jeep CJ Forum 7 08-29-2008 11:06 AM
Motorcraft 2150 ? beaver24 Jeep CJ Forum 3 05-17-2005 08:14 AM
