Motorcraft 2100 Rebuild - JeepForum.com
post #1 of 6 Old 02-02-2013, 09:50 AM Thread Starter
KajunATVer
I have a Motorcraft 2100 that needs a rebuild. There is no tag on the carb. that would let me know which kit to get but it is stamped 1.08 on the side. Does anyone know a part number for a rebuild kit for that would work for this carb? Thanks in advance for any help.
KajunATVer is offline
post #2 of 6 Old 02-02-2013, 10:02 AM
arg0413
Hey man your by BR? Me too! I just rebuilt the same carb for my CJ7 , 1.08 Venturi, #47 Jets and she runs great! I ordered from this website:http://www.carburetor-parts.com/ part #4008 for rebuild kit, and Part #120-04 for jets! CHeers!
arg0413 is offline
post #3 of 6 Old 02-02-2013, 10:11 AM Thread Starter
KajunATVer
Thanks for the info. man! Yeah I'm in Central. If you see a brown '85 CJ7 that's probably me!
post #4 of 6 Old 02-02-2013, 01:44 PM
stamp32
I just finished my rebuild and it is very easy. I used this to help me:
http://www.therangerstation.com/tech..._2150_carb.pdf
My carb did not come with a tag, but I found that in the front, driver side of the carb, near where it mounts to the manifold. There is a set of numbers that engraved. You can cross reference rebuild kit numbers there. I couldn't figure it out, so I bought several kits and just choose the one I needed. Be careful though if you open the kit most place won't return it.
I just ordered my rebuild kit from o'Reilly, $14.99
You also need a gallon can of carb dip and carb cleaner spray. Both at O'reilly. The carb dip works wonders, mine looks brand after an overnight bath.
stamp32 is offline
post #5 of 6 Old 02-04-2013, 12:08 PM
lsukevinc
1979 CJ5
if ithe carb was stock on your motor, do a search on any autoparts website. i got my rebuild kit for my 2100 at auto zone for maybe $20.
Let me know if you need some help, it is not too bad of a job.
lsukevinc is offline
post #6 of 6 Old 02-05-2013, 01:11 PM
streetpro
1978 CJ7
Mikes Carburetor Parts. First place to give me 100% perfect match every time for my 2100
streetpro is offline
