Motorcraft 2100 ID Tag Numbers - JeepForum.com
post #1 of 1 Old 02-16-2012, 01:12 PM Thread Starter
Rowinj13
1978 CJ7
Okay so it has been a while since I have posted anything here and I figured since I am looking to switch to a motorcraft carb on my CJ that I would post some info that should be helpful to others looking for motorcraft carbs
List of Motorcraft 2100 Carburetors
*Note: Although this list covers the majority of carburetors that will work with a Jeep 4.2L it does not cover all the possible variants that will work. This list will include carburetor ID tag numbers for the 1.08 (287cfm) which is known to work very well on the 4.2L, and the 1.14 (300cfm) which should also work.
289 c.i., 1.08 Venturi
C8AF-L, AF, AK,BD; C8DF-E, F; C8OF-S; C8ZF-E, G, H
302 c.i., 1.08 Venturi
D2AF-HC; D2FG-AA, AB, AC, BA, BB, BC; D2OF-JA, KA, KB; D2ZF-FB, MA; C9AF-B; C9ZF-G; D0AF-C, U;D1AF-DA, ZA; 1OF-ABA, ADA, AGA; C9UF-B
289 c.i., 1.14 Venturi
C2AF-AF; C3AF-E, F; C4AF-B, BG, DD; 5AF-B; C5ZF-A, B, G, H; C6AF-B; C6DF-A, B, E, F
352 c.i., 1.14 Venturi
C5FT-B, Y; C6TF-C
I hope this helps others when the are looking for carbs to buy.
'78 CJ7 4.2L, Dana 30 AMC 20 (3.54 Open), Dana 20, T150, Holley 390 cfm, Offy Intake, Headman Header, Team Rush upgrade, 31x10.5x15 Custom Cut Cooper Discoverer ATR's. Custom front and rear bumpers, Fiberglass tub and front clip, PO had the Engine Rebuilt in 1995. ~Visualize Using Your Turn Signals!~ Instant Gratification Takes Too Long!
Always tell the truth, that way you never have to remember what you said!
Education will take you so far, Common sense will carry you the rest of the way!
Rowinj13 is offline
Motorcraft 2100 PCV devon9988 Jeep CJ Forum 20 05-11-2011 02:23 PM
Motorcraft 2100 help! cgi2099 Jeep CJ Forum 11 09-07-2010 03:43 PM
Motorcraft 2100 HELP! cibholder03 Jeep CJ Forum 7 02-23-2009 11:44 PM
Motorcraft 2100 cj7roaddog Jeep CJ Forum 2 11-12-2007 04:37 PM
Motorcraft 2100 help wm69 Jeep CJ Forum 1 11-29-2004 07:21 PM
