Motorcraft 2100 Carb - Page 2 - JeepForum.com
post #16 of 24 Old 12-30-2013, 05:33 PM
86cj74.2L
86cj74.2L's Avatar
168 dollars for a guaranteed to work BBD. Worth every penny.
86cj74.2L is offline
post #17 of 24 Old 12-30-2013, 06:26 PM Thread Starter
krex1985
1979 CJ7
I trying to id the correct ports for the diagram it shows m s and e ports but My carb has 4 ports not 3 ports. I id the PVC port which is m. Here are pictures of the other 3 ports can you please tell me what there are? I think the first pic is the s.... But please verify and I think the 2nd pic is e and then last I think I leave capped off
krex1985 is offline
post #18 of 24 Old 12-30-2013, 06:29 PM Thread Starter
krex1985
1979 CJ7
Oh yeah and what is this one for so this port makes 5 ports.
krex1985 is offline
post #19 of 24 Old 12-30-2013, 06:49 PM
86cj74.2L
86cj74.2L's Avatar
You need to figure out what the ford carb came off of and then look at that vacuum diagram to determine what is what.
Any vacuum diagrams post by members here are going to show the porting of the Carter BBD. Which will not match your ford carb.
M is manifold.
E is emissions. Which may or may not be capped. And is most likely for the evap purge and EGR operation.
S is spark. And via the CTO can also operate the EGR and EVAP purging.
Generally the E and S porting is above the throttle plates and show zero vacuum at idle. However each one is tuned to its intended task.
post #20 of 24 Old 12-30-2013, 06:51 PM
86cj74.2L
86cj74.2L's Avatar
Just to add you can blow air or carb cleaner through the vacuum nipples. (He said nipples he he) and if its above the plates it could be spark or emissions. If its below the plates its manifold.
post #21 of 24 Old 01-03-2014, 01:27 PM
capt205
1983 CJ7
Well, not to hijack but... I ditched the 2150, and went with a reman Carter for a '79 CJ, from the above mentioned shop. I will agree with the quote...after 3 days of driving it around town, it really runs like a new Jeep.
capt205 is offline
post #22 of 24 Old 01-03-2014, 02:35 PM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
Not sure if you still need this but here is the diagram for the carb.
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #23 of 24 Old 01-03-2014, 02:52 PM Thread Starter
krex1985
1979 CJ7
Thank you
krex1985 is offline
post #24 of 24 Old 01-11-2014, 10:39 PM
86cj74.2L
86cj74.2L's Avatar
Bump for Brad! Link is on page 1 and sent a pm.
carb , carberator , motorcraft 2100 , motorcraft 2150
