Hi.
First of all, about my self.
Name is Udi, Age 37, and i'm from Israel.
Time difference is +8 Hours, So 09:00 AM here is 01:00 AM Forum time.
The car is a 1975 CJ6, Local assembly.
Engine - 258
Body - A local version of the YJ (called Storm m240 mk1).
Just installed a Motorcraft 2100 instead of the old BBD.
Vacuum at idle - 19HG
Jets - #47
Current altitude - 550m above sea level (i think it's 1800ft)
Outside temp - about 15-20C (59-68F)
Choke converted to manual (i didn't forget to plug the hot air vacuum port)
When i pull the throttle fast, engine chokes and hesitates.
If i pull it slowly, engine response is OK.
Also, when pulling throttle, i don't see a burst of gas inside the carb, which makes me believe that the acceleration pump is the cause.
Or maybe does it look like the power valve?
Got a video of it, but as i'm a newbie, forum laws don't allow me to post URL links (if i could PM the URL to someone and he'd post it as a reply, that could be great)
Thanks.
Udi :smile2:
Engine - 258
Jets - #47
Thanks.
Udi :smile2:
