motor and tranny - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > motor and tranny
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive GarRuffStuff Memorial Day Sale!
Unread 01-08-2006, 04:23 PM   #1
83renegade
motor and tranny
O.K. I ask what motor and tranny to run in an 83 CJ-7. I got alot of ideas from you. I found a 305 a friend is willing to give me if I pull it. The motor is about 7 years old with less than 10,000 miles since it was put in the truck(transmission went out). Friend says it was a crate engine and has paperwork. He is going to a big block and wants it out of his way. I now need a carb. I have had several people tell me to run a Holley Truck Avenger. Anybody have any experience with them?
83renegade is offline   Reply With Quote
Unread 01-08-2006, 04:41 PM   #2
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The Holley Truck Avenger is a decent carb. I have one on the wife's AMC 360. Loaned it to a buddy for a couple of trail rides. It handled steep inclines/off camber stuff better than the Edelbrock he was running but if you get on really steep stuff, it'll still load up. For a moderate trail rig I would say it's perfect. If you're into rock crawling and the vehicle sees enough angle to "teeter", then you'll have to work the throttle to keep it running.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 01-08-2006, 09:39 PM   #3
Rockram1
What year is the 305? Look for a TBI for it.
86 CJ7, 258, t18, D300, D44's 4.56's, Detroit front, Warn shafts and CTM joints, spool rear, SOA, SRS, waggy springs, 6 point cage, Warn winch, 38" Tsl, Allied beadlocks.
Rockram1 is offline   Reply With Quote
Unread 01-09-2006, 11:45 AM   #4
83renegade
It's out of a 84 pick-up. What's a tbi set up run? Is it about the same as the carb?
Unread 01-09-2006, 04:12 PM   #5
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
It's Throttle Body Injection (Fuel Injection) came on the V8s from what... 87 on? It's a smooth running system that's fairly easy to do. Best bet is to rip an entire system off of a junkyard vehicle.. throttle body, intake, wiring harness, sensors and computer.
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Unread 01-09-2006, 06:27 PM   #6
83renegade
I wasn't real clear on the last post.What I meant by what does it run I meant price. Is it about the same price as the carb in question or more expensive?
Unread 01-09-2006, 06:50 PM   #7
knifeboy2
A carb is likely cheaper, but you might be able to get the full TBI system from a junkyard for a good price. Plus add in the fuel ecomony you can save and convenience of not needing to warm the engine up and the hassle of a carb, and I'd say it's worth whatever extra cost it comes to be.
"If stupidity got us into this mess, why can't it get us out?" -Will Rogers
knifeboy2 is offline   Reply With Quote
