Motor swap? - JeepForum.com
post #1 of 8 Old 01-06-2010, 05:27 PM Thread Starter
Texaspipeliner
Motor swap?
Ok I know I'm gonna hear some heat over this but I wanna know exactly what to do, my 258 is I think worn out hell it don't even run right. I wanna know what's easier to swap in a chevy V8 or a amc V8? I've got 37" boggers with a T-5 and the 258 and want...I mean need more power for the setup I'm about to build I don't think a 6 cylinder will turn 44" tires but whatever. Naw I just wanna know what's easier to swap into what I got?
Texaspipeliner is offline
post #2 of 8 Old 01-06-2010, 05:36 PM
jeepskate
It should be fairly obvious that an AMC V8 swap will be easier into an AMC Jeep than a Chevy V8 would be. Turning the big tires is more about your axle gearing than the engine. I'm assuming you're planning some 1-ton axles if you don't already have them and something beefier than a T-5...
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 8 Old 01-06-2010, 07:06 PM Thread Starter
Texaspipeliner
Yes I'm getting one ton running gear, but man I'm having problems finding a amc v8, will it bolt right up to the t-5 or no?
post #4 of 8 Old 01-06-2010, 07:36 PM
southshore30
1982 CJ7
Your t-5 is going to grenade with those tires and a v8! You would not ever be in a position to use the overdrive with those tires will you? Go with a heavier trans and save yourself some time to wheel instead of wrench
southshore30 is offline
post #5 of 8 Old 01-06-2010, 07:40 PM
-AC-
1977 CJ5
SBC = easier to get HP and torque, or at least cheaper.
AMC = easier to install and make work with Jeep drivetrain.
Pick your poison...
"Damn Everything But The Circus..." e.e.c.
-AC- is offline
post #6 of 8 Old 01-06-2010, 07:42 PM Thread Starter
Texaspipeliner
I'm going to run at least 5.13 gears, and this thing is gonna be for full blown offroad like trailered anywhere I go not highway driven. I'm wanting to find a t-18. But what is gonna have to be done to swap in a amc v8?
post #7 of 8 Old 01-06-2010, 07:56 PM
caanzaldua
1981 CJ7
Take a look here for information on what works best with an AMC V8. There is a lot of good information about different engine/tranny setups at this site as well.
The AMC / Jeep V8 Engine - Novak Conversions
caanzaldua is offline
post #8 of 8 Old 01-06-2010, 08:01 PM
southshore30
1982 CJ7
If you go with the chevy, I'll recomend M.O.R.E motor mounts. makes installation as far as locating your engine mindless. Worth the $ IMO. Going AMC will keep it pure blood.
motor swap??? kw89425 Jeep CJ Forum 5 07-11-2008 10:29 AM
Motor Swap? CJBRENT Jeep CJ Forum 2 05-08-2008 05:20 AM
Cj Motor Swap To A 4.3L CJBRENT Jeep CJ Forum 8 10-22-2007 04:29 PM
CJ7 motor swap to a 350. 86cj7laredo Jeep CJ Forum 5 07-25-2006 12:12 PM
cj motor swap but what motor need help flip2spin Jeep CJ Forum 3 01-21-2004 07:11 AM
