motor swap in 81 CJ5 can't decide what motor!!!!!!!!!!!!!!!!!HELP!!!!!!!!!!! - Page 2 - JeepForum.com
post #16 of 51 Old 09-10-2011, 02:12 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
Originally Posted by truckshop21 View Post
would you ship it? how much? does it need to be rebuilt?
i would but i have no idea how much it would be for shipping. and no its a good tranny that was mated to a 304
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #17 of 51 Old 09-10-2011, 09:00 PM
ComancheCounty
You sir are already enroute to Jeep Hell for even considering a non Jeep/AMC engine. Blasphemous! Save yourself and go buy a 304/360/401,,,,,,NOW!
ComancheCounty is offline
post #18 of 51 Old 09-10-2011, 09:09 PM
afgd1
i have a friend thats working on trying to put the diesel in his cj7 and a 4 or 5 speed trans in it i think its a izuzu or dodge small block ill call and ask him and put post here if i find out what it is but he knows some one who did it bet it has great power and fuel mileage
afgd1 is offline
post #19 of 51 Old 09-11-2011, 08:48 AM Thread Starter
truckshop21
1981 CJ5
can you get a quote to ship to 33306 zip code and how much for the tranny?
truckshop21 is offline
post #20 of 51 Old 09-11-2011, 08:49 AM Thread Starter
truckshop21
1981 CJ5
i know someone who did that and he used the izuzu motor.
post #21 of 51 Old 09-11-2011, 08:50 AM Thread Starter
truckshop21
1981 CJ5
how much am i going to be looking at paying for a good running amc 360 or 304 and what about rebuilding one?
post #22 of 51 Old 09-11-2011, 10:06 AM
Chewtoy
1976 CJ5
Depends on you area. Here in ID There are adds in CL for $200-400.
Lots of people will tell you not to bother with a 304, but quite frankly mine has loads of power for a CJ5. I am thinking a 360 would be kind of scary in a mostly stock 5. Anyway I'm just saying don't go out of your way to avoid one, the are a fine motor.
With a great Jeep comes an empty wallet.
Chewtoy is offline
post #23 of 51 Old 09-11-2011, 05:21 PM
RobsCrawlin7
no balls
i got my 360 for $150. it runs great and is super clean inside. i had to replace the pan as the guy i bought it from didnt set the lift chains right and it fell so while i was there i did the bearings. good deals are out there.
and i will try to get a quote for you in the next day or 2 but i am sure it wont be worth it. prob cost just as much to ship as im charging for it lol.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #24 of 51 Old 09-11-2011, 08:32 PM Thread Starter
truckshop21
1981 CJ5
one thing i dont really get is how would an amc motor be cheaper then a SBC? still need motor mounts and a radiator.
post #25 of 51 Old 09-12-2011, 07:00 AM
Stumpbumper
You have a GM 90 deg bell housing behind the 151 Iron Duke. A Chev V8 or 4.3 will bolt to the existing setup, I know quite a few guys who have done this. Although the trany is a lighter trany! I agree it should be changed but you could get on the road and go from there.
I wheel with some guys who have 350 chevs with auto's in flatys! This setup has been done and can be a good thing when its done correctly. There are tools out there to deal with driveline issues!
Your motor mounts have to be changed anyway! keep that in mind.
1984 CJ7, 258..HEI..MC2100, T176/D300, D30/M20 lockers, lift, warn winch!
"When in doubt! Gas it out!"
Stumpbumper is offline
post #26 of 51 Old 09-12-2011, 07:37 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
Didn't his 5 come with a GM engine?
The SBC swap will be the easiest swap for the OP.
The OP's bell will bolt up to the SBC and not an AMC engine.
The engine mounts will have to be changed for either an AMC or a SBC.
To the OP.
Find a T176 out of a CJ and tap your bell housing.
Install it to a SBC and get your drive shafts made.
MY $.02
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #27 of 51 Old 09-12-2011, 09:45 AM Thread Starter
truckshop21
1981 CJ5
thats why i was wondering how a amc would be easier if i already have a gm bell housing and i was planning on going to a t176 cause its the easiest swap and should hold up to a v8 and pretty close to the same length as my current tranny the SR4 plus no pricey adapter is needed. so I'm think........
motor mounts
radiator
sbc v8
t176
and thats its i should be able to mount the motor to where i don't have to change my driveshafts right???????
To the OP.
MY $.02
Jeff
post #28 of 51 Old 09-12-2011, 09:53 AM
jcal73
jcal73's Avatar
2015 JK Wrangler
You might, but there is no way of knowing until you get the install done.
I was able to use the stock location for the tranny and tcase.
I reused my front shaft, but had a cv shaft made for the rear and cut and rotated the amc 20 to match.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #29 of 51 Old 09-13-2011, 03:01 PM Thread Starter
truckshop21
1981 CJ5
Its hard.to.find a motor and tranny down here in.south florida
post #30 of 51 Old 09-13-2011, 04:18 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I have a running 258 and Dana 300 if you're interested. I sold the T-176 2 days ago for $300. I just parted out my 80 due to frame rot I found. Wasn't worth fixing and I still have my 83 CJ7. Where are you in Fl?
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
4cyl , chevy v8 swap , cj5 , lift , mud
CJ Motor Swap from 4.2 to 4.0 JeepinJim24 Jeep CJ Forum 2 03-09-2011 03:53 PM
Wiper Motor Help Needed, New Motor Does Not Work... poppatello Jeep CJ Forum 4 02-18-2010 07:38 AM
CJ8 Motor swap kevinrdyck32 Jeep CJ Forum 5 09-30-2009 10:28 AM
Motor Swap? CJBRENT Jeep CJ Forum 2 05-08-2008 05:20 AM
cj motor swap but what motor need help flip2spin Jeep CJ Forum 3 01-21-2004 07:11 AM
