Motor Swap - JeepForum.com
post #1 of 2 Old 05-29-2003, 01:30 AM Thread Starter
icarus00000
Motor Swap
Hey guys...
Heres the question and situation.
I have a 1986 CJ7, 4 cyl, 4 speed (T4), manual steering, manual brakes.
I have the chance to buy a running, registered and inspected 1978 Wagoneer. The motor is a 360, and has power steering, and of course, the th400 and quad unit. The motor has 130,XXX miles or so, but starts right up, and doesnt burn oil.
I was thinking this would be a awesome donor to replace my weak 4 cyl motor, and also, upgrade to power steering as well. Plus, have all the parts I need from the donor (almost)
My questions are:
1. Would I be able to use the radiator ? Or is it to large ?
2. What is needed to make everything mount up ? ie, tranny & transfer case etc. Should I look for a 3 spd instead from an older CJ to mate up to the 360 ?
3.Would anyone else be interested in whats over ? lol
I know there are more questions, but its late, and just need to know if its worth doing, or should I save the cash, and upgrade to a newer, fuel injected motor. ( vortec )
Thanks
icarus00000 is offline
post #2 of 2 Old 05-29-2003, 08:29 AM
kev1
I can't give you a lot of answers, but I can share with you a little about my experience thus far in my 1980 CJ7 rebuild project.
I started with the GM-151 4 cyl. engine andwanted to upgrade, plus the SR4 transmission needed work. So I checked into many different options and heard a lot of people try to talk me into doing the 360 upgrade.
I chose to put in a 258 thinking it would be much easier and less expensive. Plus I wanted the torq and, I was told that I could increase my HP with a Weber, Headers, and HEI. So that is the path I went down.
This simple upgrade has many side effects. First I thought I could re-use my existing Drive Shafts. Nope, they needed resized or replaced. The 258 moved the bell housing back so the drive shafts lengths were wrong.
I had to get a new bell housing for the Ultimate T5 (beafed up T5) I bought. I had to get a new radiator, you will too. I had to get new Accessory brackets. I am not done yet, but this project is costing me more than I thought, I think they all go that way.
From what I have read and the people I have talked to, you will need to lift your Jeep so the oil pan on the 360 will clear. My lift, a little 2.5", changed the slopes of the driveshafts so I went with a CV rear drive shaft from Tom Woods, and while I was at it bought a Tom Woods front drive shaft. This also requires taking the wedge out of the Springs that came with the lift kit and replacing them with more tilt.
I don't want to scare you, but this has been my experience so far.
1980 CJ7 Rebuild:
Frame painted with a Rough Country 2.5" lift and shocks installed.
Alot of money spent on parts that are all over including a new 258.
kev1 is offline
Motor swap? Texaspipeliner Jeep CJ Forum 7 01-06-2010 09:01 PM
Motor Swap? CJBRENT Jeep CJ Forum 2 05-08-2008 06:20 AM
CJ7 motor swap to a 350. 86cj7laredo Jeep CJ Forum 5 07-25-2006 01:12 PM
motor swap 83renegade Jeep CJ Forum 6 12-08-2005 08:25 PM
cj motor swap but what motor need help flip2spin Jeep CJ Forum 3 01-21-2004 08:11 AM
