Motor Swap - JeepForum.com
post #1 of 9 Old 01-01-2012, 12:39 PM Thread Starter
tarheelboy
Motor Swap
I currently have an 85 CJ7 with a 304, I want to swap back to a 258. The previous owner put the 304, and I don't want anything to do with the motor. It has a 3 speed tranny. Can I stick with the 3 speed? What else would I need to switch out and far as the drive train? The only reason for the swap other than I don't like the 304, is the 304 needs a rebuild.
Any help would be much appreciated.
Thanks
Ashley
tarheelboy is offline
post #2 of 9 Old 01-01-2012, 01:08 PM
79indcj7
1979 CJ7
Pretty sure 3 spd will work. However i think u will have to move the motor mounts on the frame because the 6 is longer.
79indcj7 is offline
post #3 of 9 Old 01-01-2012, 01:21 PM
mopar408
1974 CJ5
flywheels are different.....
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #4 of 9 Old 01-01-2012, 01:29 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
Motor mount to frame is different on passenger side. I have a freshly powdercoated 1 if you want it. Do you have a 258 also? If not, you know to get every part ya can off it. Balncer to flywheel. T-150 trans will bolt up.
BTW Mopar408...any relation to Mopar346?
hutch1200 is offline
post #5 of 9 Old 01-01-2012, 01:36 PM
arkiemurph
Here's the sticky thread on swapping FROM a 258 to a 304 or other AMC V8.
http://www.jeepforum.com/forum/f8/of...thread-377983/
Unless you're set on a 258, you may want to look for a 360. They're pretty common cause they were in a lot of the old full size Jeeps like Wagoneers and Jeep pickups. It would also be easier since your already set up for an AMC V8.
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline
post #6 of 9 Old 01-01-2012, 04:43 PM Thread Starter
tarheelboy
Thanks for all the help. Yes I am in the market for a 258, and pretty dead set on it. I had a CJ5 before this one with the 258, and it was a beast. I dang near melted the motor from a fire and it cranked right back up and ran fine. So I am sold on those motors. I don't think it will be a hard swap, but it will be interesting.
post #7 of 9 Old 01-01-2012, 05:35 PM
arkiemurph
It won't be hard. Like said, you'll need one motor mount, swap ur gas line to the pass side, redo ur exhaust. I'm thinking that's about it. One plus is you'll have a lot more room to tinker around in your engine compartment!
M
post #8 of 9 Old 01-08-2012, 05:15 AM
sequoia123
Question, I have a 1974 cj5 and the 304 just went kaput ,needs a rebuild.. Would really like something w/ better gas mileage, and a somewhat painless swap would be nice too. what would be the easiest swap for me ,besides a 304 or 360. I am a welder so a mount or two wont be a problem. does anything bolt right up to the original 3 speed tranny? I think its the T15.
sequoia123 is offline
post #9 of 9 Old 01-08-2012, 06:01 AM
arkiemurph
Read the link I posted above. Good luck with mpg's! Fuel injection seems to help the most. Also make sure u run the right gears for ur tire size. Don't run 36's with 3.31 gears like some jackwagons do thatncant afford a gear swap and isn't smart enough to do it himself.
Murph
Happy Birthday Elvis
motor swap in 81 CJ5 can't decide what motor!!!!!!!!!!!!!!!!!HELP!!!!!!!!!!! truckshop21 Jeep CJ Forum 50 09-15-2011 11:21 PM
motor swap ward1980cj Jeep CJ Forum 9 07-09-2009 09:28 PM
Got the motor for the swap! scrible Jeep CJ Forum 12 10-31-2006 07:34 PM
cj motor swap but what motor need help flip2spin Jeep CJ Forum 3 01-21-2004 07:11 AM
