Motor quit INSTANTLY, why??? - JeepForum.com
post #1 of 9 Old 04-22-2010, 07:40 PM Thread Starter
DP123987
1975 CJ5
Hey everybody, have a problem that I hope isn't bad! I just put in my t150 tranny to my 360, the motor ran before I put in the tranny. When I put the tranny in and started it, it ran for about 7 to 8 seconds and came to a fast stop! Didn't tear into it, because I was crying! Spent alot of money on that motor to. Just asking if anybody would to have a clue to whats wrong with it before I try to get the tranny out again. Thanks guys!
DP123
DP123987 is offline
post #2 of 9 Old 04-22-2010, 08:03 PM
CrazyHorse6
1979 CJ7
Did it seize or die? Are you getting spark? Does it turn when you crank it? Need some more info!
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #3 of 9 Old 04-22-2010, 08:23 PM
Felonious_monk
Broken timing chain?
88YJ
53CJ-3B
Felonious_monk is offline
post #4 of 9 Old 04-22-2010, 09:02 PM
zillla
1930 VJ
Tranny lock up??
zillla is offline
post #5 of 9 Old 04-22-2010, 09:10 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
You said you just put the trans in.... did you fill to proper level with fluid? If not, trans is probably locked up.
Rick
Cutlass327 is offline
post #6 of 9 Old 04-22-2010, 09:21 PM
Trapshooter
As CrazyHorse6 stated: We need additional information in order to help.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #7 of 9 Old 04-23-2010, 06:50 AM
Andy5150
My 360 died like that about 6 months ago, and it turned out to be the ignition module in the cheap-*** HEI.
Andy5150 is offline
post #8 of 9 Old 04-23-2010, 07:08 AM
GP_Pete
Aside from your tranny engaging or seizing, that sounds like an electrical problem. It's amazing how one stupid wire can kill your engine.
Maybe you smashed our fuel line on the inside of the frame rail installing the new tranny? The 7 or 8 seconds could've been the fuel in the lines to the engine, and once that was used up... no runny.
Need more info. describe the symptoms.
GP_Pete is offline
post #9 of 9 Old 04-24-2010, 09:09 PM Thread Starter
DP123987
1975 CJ5
You guys are great, it was a electrical problem, that toasted my starter. Took the starter apart and the whole back of it was broken apart. Dont have all the ignition done so I was using a little push button. When I started it one of the wires I had laying around( which I shouldn't have) shorted and made the starter acually stay on! MY DUMB! Just exploded the starter, and not the engine, Thank Goodness! I THANK all you for your input and helped me figure it out!
DP
DP123987 is offline
tranny problem
86 CJ7 Voltmeter Quit foggybottombob Jeep CJ Forum 11 05-18-2010 01:05 PM
CJ7 just quit running????? SlikRic Jeep CJ Forum 14 08-14-2008 09:52 AM
speedo just quit cjyj85 Jeep CJ Forum 6 11-28-2007 09:00 PM
85 CJ7 just quit Truck633 Jeep CJ Forum 2 02-28-2007 12:20 AM
wipers quit NJCJ7 Jeep CJ Forum 1 02-09-2004 12:18 PM
