Motor Mount location for AMC 258 - JeepForum.com
post #1 of 5 Old 09-24-2006, 03:55 PM Thread Starter
AMC Power
I am currently swapping out my AMC 150 for a AMC 258. Do I have to relocate the motor mount frame brackets or will they work in the same location? Has anyone done this swap before?
AMC Power is offline
post #2 of 5 Old 09-24-2006, 08:58 PM
gosupes
I have done it. The frame mounts are different from the 150 to the 258. On one side (pass side), you won't have a choice as you will use the outside pair of frame holes. The drivers side, you will use the front pair of frame holes. PM me if you need more info, or post back. There are a couple of others who have done this swap.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #3 of 5 Old 09-24-2006, 09:10 PM Thread Starter
AMC Power
What do you mean by the outside or inside pair of frame holes? Do you have a picture of this?
post #4 of 5 Old 09-25-2006, 06:36 AM
gosupes
There are 3 pairs of holes in the frame rails where the motor mount brackets bolt up to for use with different engine and trans combos. Just for reference, number them pair 1 (towards the grill), pair 2 (middle) and pair 3 (towards the rear). The passenger side motor mount bracket uses pairs one and three and the drivers side uses pairs one and two. The 258 is at least 10" longer then the 150. Everything will get relocated. If you want a pic, you will have to wait until I get home later.
gosupes is offline
post #5 of 5 Old 09-25-2006, 11:20 AM Thread Starter
AMC Power
Thanks for the info! I took the old mounts off and now I see the 3 pairs of holes. The new mounts line right up with the bolt holes.
Blower Motor fuse location? Mudviper Jeep CJ Forum 3 01-03-2010 09:59 AM
Transmission mount location on T176 & 304 in 86 CJ7 dougoruss Jeep CJ Forum 3 04-17-2009 04:25 PM
Front shock mount location sed437 Jeep CJ Forum 4 06-06-2008 11:01 AM
AMC 360 motor mount location drespecki Jeep CJ Forum 6 09-03-2007 01:47 PM
83 CJ Wiper Motor Location warden Jeep CJ Forum 7 04-14-2006 05:28 PM
