motor mount engine brackets - JeepForum.com
post #1 of 6 Old 11-04-2007, 05:44 AM Thread Starter
Andy5150
Good morning everybody! I finally got my amc 360/t18 combo ready to drop into my 82' cj-7. It originally had the 258. I bought the v-8 motor mounts, and the v-8 passenger side frame mount. The 360 is from an 81' jeep truck. I cant' seem to get the engine to fit. I did reuse the brackets that actually bolt to the engine. My question is are the engine brackets from a jeep truck with a v-8 the same as the the ones for a v-8 cj-7, or do I need cj-7 v-8 engine brackets? Any help would be grately appreciated. Thank You.
Andy5150 is offline
post #2 of 6 Old 11-04-2007, 06:03 AM
high51977
I do believe you need the CJ engine mounts Somebody who has done this will speak up for sure and correct me if I am wrong
Play by the rules you're gonna miss all the fun
high51977 is offline
post #3 of 6 Old 11-04-2007, 06:50 AM
John N
1981 CJ8
Those brackets are different, I've heard. I used the MORE Bombproof mounts, they replace everything between the engine block and frame.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #4 of 6 Old 11-04-2007, 07:19 AM
krazyzigzagger
1976 CJ7
V8 Engine Swap
Look at the thread directly above this section for the details.
krazyzigzagger is offline
post #5 of 6 Old 11-04-2007, 07:29 AM
jp360cj
1977 CJ7
I ran into the same problem when swapping in a 360 for a 258. I'm guessing the truck frames are wider and that's why the engine mounts don't work. anyway, all the v8 in the CJs have the same motor mounts, so i found a set from a 304.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #6 of 6 Old 11-04-2007, 10:25 AM
hfjeff
hfjeff's Avatar
The block mounts are different as well. These are the brackets that bolt directly on the block. You need V-8 CJ mounts. You can get them on E-bay or JeepDoc.com.
MINE: 1995 YJ/2.5L/115K/Completely Stock
MY DAD's: 1978 CJ7/ AMC 360 .030" over/ Motorcraft 2100/ Edelbrock Performer/ Proform HEI Ignition/ Hedman Headers with dual Flowmaster 40's/ Taurus Fan/ FK-35 Control/ Painless Harness/ Rebuilt T150 & Dana 20/ 4" Lift/ 31" Procomp Mud Terrains/ All Fiberglass. (SOLD)
MY BROTHER's: 1996 ZJ Limited/5.2L/117K & Completely Stock.(SOLD)
hfjeff is offline
Stock Motor Mount Frame Brackets 243 Jeep CJ Forum 6 02-02-2009 08:41 PM
Need motor mount engine plates fabricated 258 mounts to 2002 4.0 whittlecj Jeep CJ Forum 23 11-29-2008 11:50 PM
Motor Mount Brackets 2.5 to 4.0 Swap joemac421 Jeep CJ Forum 5 09-23-2008 12:18 PM
MORE V8 mount guys... how far forward did you mount your frame brackets? Aaroneous Jeep CJ Forum 11 05-06-2008 07:10 PM
258 motor mount brackets AMC Power Jeep CJ Forum 2 10-10-2006 10:51 AM
