Motor Mount Brackets 2.5 to 4.0 Swap - JeepForum.com
post #1 of 6 Old 09-22-2008, 07:16 AM Thread Starter
joemac421
joemac421's Avatar
I know I need new motor mounts to do this swap, but the motor mount brackets are bolted through the frame. Can I just drill new holes and move the existing brackets? I would think I would have to do something for the strength of the frame. Please Help.
Better to have Jeeped & Rolled Over then to never have Rolled Over.
joemac421 is offline
post #2 of 6 Old 09-22-2008, 09:20 AM
1TonJoe
Bracket Swap
I just did a similar swap. I replaced my 92 4.0 frame with a 91 2.5 frame. I measured the distance from shock towers to the leading edges of the motor mount brackets on the 4.0 frame. Using a cut_off wheel and grinder, I removed the frame brackets on the 2.5 frame. I welded new 4.0 brackets, from chrysler dealer, onto the 2.5 frame. I REUSED THE ACTUAL MOTOR MOUNTS but I started with a 4.0. You may need new mounts. I also kept my AX15 so I did not have to do anything with the trans mount. Let me know if you need the shock tower to bracket measurements and I'll get the measurements tonight. I think it was like 1" driverside and 3" passengerside. Mine bolted right up~ no problems.
GOOD LUCK! - Joe
1TonJoe is offline
post #3 of 6 Old 09-22-2008, 09:23 AM
jeepskate
This is the CJ forum...he doesn't need to go through all of that on a CJ. Pick up a set of brackets off of a '76-'86 CJ that had the 258...they bolt right up to your frame and to the 4.0...the block is nearly identical to the 258/4.2. You can also use aftermarket mounts like MORE Bombproofs. I've done this a couple of times as have many others.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #4 of 6 Old 09-22-2008, 11:48 AM Thread Starter
joemac421
joemac421's Avatar
Jeepskate, I got that, but Do I have to redrill the frame or are the brackets offset? I thought that I had to move them or at least one on the pass. side?
post #5 of 6 Old 09-22-2008, 03:00 PM
1TonJoe
Cj~yj
Sorry guys, didn't realize I was in CJ Tech! Good Luck!!!!!!!!!
Joe
1TonJoe is offline
post #6 of 6 Old 09-23-2008, 12:18 PM
jeepskate
I'm 99% certain that you don't need to redrill the frame...should mate up properly between the holes that are already there and the way the brackets sit.
Is this an old motor mount? Doing v8 swap, and it's in my way Big_Pete1999 Jeep CJ Forum 36 11-22-2009 01:37 PM
V8 swap motor mount question homebrew91 Jeep CJ Forum 3 02-03-2009 10:24 PM
Stock Motor Mount Frame Brackets 243 Jeep CJ Forum 6 02-02-2009 08:41 PM
motor mount engine brackets Andy5150 Jeep CJ Forum 5 11-04-2007 10:25 AM
258 motor mount brackets AMC Power Jeep CJ Forum 2 10-10-2006 10:51 AM
