For a mostly road CJ5, is it better to go with a spring over axle lift or coil over? - Page 2 - JeepForum.com
post #16 of 20 Old 11-21-2010, 04:36 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
My CJ5 rides on RE "Standard" 4" YJ springs.. mounted SUA. I've got 4" (eye to eye) shackles and Rancho RS9000 shocks at all 4 corners. Also running 35" KM2s with about 18-20 psi in them.
I'm still amazed by the ride.. it is the softest riding "short Jeep" I've ever ridden in.. seriously. Matter of fact, I adjusted the shocks to the stiffest setting to get some of the "road feel" back. Only thing I'd like to add would be a Currie Anti-Rock or some other custom adjustable swaybar setup.. to combat body roll in turns. Other than that, the setup rides like you're on clouds..
BESRK is offline
post #17 of 20 Old 11-21-2010, 05:06 PM Thread Starter
jlrray
When you say standard do you mean stock? Or you just bought any brand Wrangler 4" suspension lift and got a CJ / Wrangler adapter?
jlrray is offline
post #18 of 20 Old 11-22-2010, 02:20 AM
vettester
1978 CJ7
I agree with everyone else..... about good bushings etc. Personally I think that maybe a good set of adjustable shocks would be a good first step. Some of the new ones are amazing in their range of adjustment, plus they let you adjust rates for the front and rear independently with a little knob on the bottom .........
vettester is offline
post #19 of 20 Old 11-22-2010, 08:19 AM
CSP
Not stock. Rubicon Express (RE) sells a "standard" line and an extreme line of lift springs.
CSP is offline
post #20 of 20 Old 11-22-2010, 03:37 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Exactly.. the "Extreme" version is the expensive kit and the "Standard" version is supposed to be the budget kit..
The kit was pretty complete.. DT3000 shocks, extended brake lines.. etc. However, I sold the shocks off as I already had some 10" travel RS9000s.
I later swapped the front shock mounts for hoops and installed some 12.5" travel RS9000s that I got off eBay.
So.. with that "budget kit" mounted SUA with some longer shocks, my CJ5 rides great and flexes like this...
BESRK is offline
lift advice , spring over axle , suspension
SPRING OVER AXLE- roughly how much lift do you get?is it better then a 4" +body lift? jeepcj7 Jeep CJ Forum 12 05-02-2012 09:33 AM
Need info on the rocky road spring over axle kit!!! cj7major77 Jeep CJ Forum 44 03-08-2010 08:23 AM
Spring over Axle lift Jeremy71655 Jeep CJ Forum 6 05-17-2009 01:18 AM
Spring over axle lift wyrenuts Jeep CJ Forum 10 03-11-2009 02:03 PM
How to put 4 in lift spring over axle on 83 cj7 louie4play Jeep CJ Forum 3 05-25-2007 10:58 PM
