For a mostly road CJ5, is it better to go with a spring over axle lift or coil over? - JeepForum.com
post #1 of 20 Old 11-15-2010, 09:54 PM Thread Starter
jlrray
I love my jeep... Just not the ride. I'm not asking for a new SUV feel, just something better. I have an old 2.5" National Springs lift on my 78 CJ5 running 33" x 12". This is mostly a road jeep, so I need a better ride. Would a spring over axle lift give me better results? Should I go with a coil over conversion? Would it be good to reverse the front shackles? I just need some guidance here. Coil over looks really expensive.
Joe
jlrray is offline
post #2 of 20 Old 11-15-2010, 10:01 PM
tacjeep99
I would think a SOA would ride much worse given the nature of the modification. Coilover conversion would probably ride better, but there is a lot of expense to doing it, and in the end you still have a short wheelbase CJ-5 that is probably not going to ride a whole lot better than stock.
tacjeep99 is offline
post #3 of 20 Old 11-15-2010, 10:14 PM
benullman
1981 CJ7
I would get a shackle reversale kit. From what I have heard they improve the onroad ride quite a bit.
dont forget to check the front drive shaft for travel!
Ben
benullman is offline
post #4 of 20 Old 11-15-2010, 10:15 PM Thread Starter
jlrray
What about going SOA with Wrangler springs?
jlrray is offline
post #5 of 20 Old 11-16-2010, 03:43 AM
John Strenk
John Strenk's Avatar
1976 CJ5
With Wrangler axles also? It will be very expensive to go to coil but it would be a nice ride. Oh wait I'm sorry, you mean YJ Wranglers leaf springs, my Wrangler has coils, I forgot some Wranglers don't
Seriously, the ride will be so tippy with those NT axles. If your looking for softer springs, SOA you're going to need to add sway bars and maybe a track bar also.
IMHO, you need to get wider axles and then go with the shackle reversal for a better ride. An adjustable set of shock also.
Is this going to be a DD vehicle? I think a SOA lift on a NT CJ5 is like a really hot chick. Fun to take out every so often but not something you want to live with day after day.
John Strenk is offline
post #6 of 20 Old 11-16-2010, 07:24 AM
Cherokeester
Cherokeester's Avatar
1980 CJ7
I think you would be better off going with a real quality spring under set of springs. What you are asking is what people do for a better off road Jeep.
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline
post #7 of 20 Old 11-16-2010, 09:09 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
This. Stay SUA. SOA gives a LOT of lift, even with stock springs. Scary on a street-driven CJ-5.
Get some quality springs and keep it the way it is....you're not going to make it much better, but those are some really old springs you have.
Old Man Emu is noted for good-riding springs.
You could custom-order a set from somewhere like Alcan...you fill out an online form with lots of info about your Jeep, then they call you and ask a ton more questions about it, like what you are primarily going to use the Jeep for, etc....then build the springs to your liking.
Pacfanweb is offline
post #8 of 20 Old 11-16-2010, 10:54 AM
Happy Joe
Yup! For the street keep the springs under.
Soft replacement springs are becoming much more common, give Rubicon Express a call and emphasize that you want a soft ride.
Be careful not to get heavy duty shocks (Ranchos, etc) as your ride will suffer.
Get quality OEM style shocks, of the correct length, for the best ride.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
post #9 of 20 Old 11-16-2010, 11:03 AM
CSP
Spring under with a custom made spring like those available from Alcan or National spring.
x2 on a properly valved shock. Doetsch-Tech or Bilstein are good brands which will have more valving options.
CSP is offline
post #10 of 20 Old 11-16-2010, 11:09 AM
Jeepican
1976 CJ5
just go with RE ... it converts to the yj and also buy a shackle reversal....the higher a cj5 the scarier....
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #11 of 20 Old 11-16-2010, 11:13 AM
Boodyrider
Another point is that if the old shackles and spring eye bushings are either worn or siezed, the ride will suck. Greasable bushings would be a good investment. Also go with a YJ conversion, the 2 1/2" springs ride better and are more stable.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #12 of 20 Old 11-20-2010, 11:55 PM Thread Starter
jlrray
so i'm hearing something like put a YJ spring on a CJ5 with a reverse mounted shackle and greasable bushings... Sounds about right?
jlrray is offline
post #13 of 20 Old 11-21-2010, 12:00 AM
benullman
1981 CJ7
post #14 of 20 Old 11-21-2010, 11:32 AM
1982cj8
Get the Old Man Emu springs and shocks, my daughters rig had these and it was the best riding leaf spring jeep i have ever driven. They make a kit to convert the YJ springs to CJ but all you need are some rear spring hangers to bolt on the front. If going reversal then set it up for Yj springs.
Always bring a compass, it is awkward to have to eat your friends.
4X4XNORTHWEST.COM
1982cj8 is offline
post #15 of 20 Old 11-21-2010, 11:41 AM
JeepsOLot
I heard BDS makes some excellent riding and flexing springs. My 10 yr old Rancho 2.5" lift, Bilstein 5100's, and MORE 5/8" booms with greasable shackle bolts make mine ride like a dream, but, this is for a YJ.
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
lift advice , spring over axle , suspension
SPRING OVER AXLE- roughly how much lift do you get?is it better then a 4" +body lift? jeepcj7 Jeep CJ Forum 12 05-02-2012 10:33 AM
Need info on the rocky road spring over axle kit!!! cj7major77 Jeep CJ Forum 44 03-08-2010 09:23 AM
Spring over Axle lift Jeremy71655 Jeep CJ Forum 6 05-17-2009 02:18 AM
Spring over axle lift wyrenuts Jeep CJ Forum 10 03-11-2009 03:03 PM
How to put 4 in lift spring over axle on 83 cj7 louie4play Jeep CJ Forum 3 05-25-2007 11:58 PM
