Moser One Piece Axles install - remove the thrust block? - JeepForum.com
post #1 of 15 Old 09-08-2013, 11:02 AM Thread Starter
CJ7KAHUNA
I am getting ready to order Moser one piece axles so I've been doing some research on the installation as I've never done it before. While reading threads on here there seems to be quite a few people that have bearing and seal issues. I recall reading a thread where JEEPHAMMER mentioned an issue with the thrust block in the differential. Beings it was the only post I ran across that mentioned the thrust block I thought maybe it was a situational issue. I was doing a google search last night and ran across this post over on jeepsunlimted forum - posted by a senior moderator that goes by CJSIXER:
"Another tip for installation involves the trust block. The thrust block is a metal block with a hole in the center that is about two inches long and rides on the cross shaft in side of the carrier, basically in the center of all of the spider gears. I personally feel that based on problems that customers have had and called about in the tech dept at 4wd that the block should be removed. Because one piece axles change the way that your bearings are installed you will no longer need this block, it is there for bearing preload in the two peice set up. I feel that even if you can get you axles all of the way in you will still have accelerated bearing and seal wear. We try to get most customers to do this. To remove it all you have to do is pull the cross shaft and it should drop out. Then just put the cross shaft back in. The shims that some one refered to will also be left out. They were also for only the two peice set up."
I would like to hear opinions on this as it is not referenced in any of the Moser instructions that I've seen. If it helps with bearing life and has no adverse effects maybe its a good idea? Thoughts? LG Whatcha got?
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
post #2 of 15 Old 09-08-2013, 11:46 AM
jeepwhore
The way most one pc kits are designed you no longer need the t-block. The way the 2 pc set up works, one shaft assembly is mounted tight to the housing flange. The other shaft is inserted and pushes on the thrust block and the end of the first shaft, effectively making a solid shaft from one side to the other. Then shims are added behind the backing plate of the second side to get the specified end play.
Since 1 pc shafts use bearing protrusion to set pre-load neither the t-block or shims are required. I don't see how leaving it in would extend bearing or seal life. The side gears support the inner end of the shaft and the bearing supports the outer end. With a 1 pc set up bearing life is dictated by the retainer ring staying put, the bearing surface in the housing being un-marred and the housing being straight.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 15 Old 09-08-2013, 11:51 AM
WindKnot
1977 CJ7
Mine has been gone for a long time. I don't miss it.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #4 of 15 Old 09-08-2013, 12:09 PM Thread Starter
CJ7KAHUNA
The way I understand the post I quoted - leaving the thrust block in may lead to premature bearing failure.
I am guessing the consensus is to remove the thrust block as an installation step?
post #5 of 15 Old 09-08-2013, 01:31 PM
skizriz
1978 CJ7
The moser instructions say to remove the block.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #6 of 15 Old 09-08-2013, 02:06 PM Thread Starter
CJ7KAHUNA
These are the instructions I have downloaded - am I just missing it?
post #7 of 15 Old 09-08-2013, 02:36 PM
jeepwhore
Could be they slightly altered the length of their shafts (giggle) so that the thrust block could be left on place and no longer needed to be mentioned. best bet is to call them though to be sure.
post #8 of 15 Old 09-08-2013, 03:16 PM
skizriz
1978 CJ7
I just put Mosers in mine a few months back, and know I saw it somewhere. I put a Lock Right in at the same time, I'm wondering if I didn't see it in those instructions.
I do remember seeing it somewhere though. It's tough getting old.
skizriz is offline
post #9 of 15 Old 09-08-2013, 03:32 PM Thread Starter
CJ7KAHUNA
Those instructions may be out dated - I forgot what link I got them from. Age is a cruel mistress indeed
post #10 of 15 Old 09-08-2013, 03:35 PM
jetmech1
No they don't, unless they've updated their website within the last few months.
jetmech1 is offline
post #11 of 15 Old 09-08-2013, 04:06 PM
LumpyGrits
The last set I put in, you had to.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #12 of 15 Old 09-08-2013, 04:12 PM
skizriz
1978 CJ7
I went off of the instruction sheet that came with the axles. Possible that it's been updated on the printed instructions....
Until I put the axles in, I had never heard of a thrust block. That's why I am ALMOST positive that I saw it somewhere.
skizriz is offline
post #13 of 15 Old 09-08-2013, 08:46 PM
only in a jeep cj
I slid in a set of Mosers the other day into a spare axle. I left the thrush spacer in and both went in with the bearing edges flush with the tube flange. Now maybe I had a really worn spacer as there was about 160K on the axle.
Just in case someone is confused on the bearing orientation, The tapered bearings in the OEM (2 piece design) face out with the race thick section toward the tire. This means when the weight is on the bearing, the axle is pushed inward. The race is held in place by the drum backing plate and the bearing is pressed onto the axle shaft (before the hub is installed) and seats against a built in bearing stop on the axle which is the seal surface for the inner seal. So both axle shafts press in against a 2 inch or so section of round stock called a thrust block. IF the total distance of the right side outer race edge to the left side outer race edge is larger than the axle tube flange edge to edge, shims are used on the drivers side to achieve the correct endplay to allow bearing movement and heat expansion, etc.
The Mosers and Superior units have the bearing facing the other way so the weight on the bearing pushes it outward. Again, the backing plate holds it on the outside and a pressed on ring holds the bearing. The races thick section is toward the inside and what keeps it from going further into the tube is a spacer that is special to these one piece axle swaps. It is trimmed to allow the correct bearing orientation at the tubes end.
That said, AS LONG AS the thrust block isn't contacted by the ends of the two axle shafts, it should be fine. If the thought of the thrust black floating around loose on the cross shaft bothers you, remove it. Now if when installing the second shaft, you find that you can't insert the bearing fulling to achieve the specified measurement, YES, the thrust block will need to be remove. My view is to check first.
As a side note, I have another set of one piece axles that I bought second hand years ago. What I noticed is that the bearings are installed like the two piece axles (race toward backing plate) and have a huge press ring holding it on. Its more like a huge pressed on collar. and Im guessing it uses the thrust block as well. Anyone know of this brand?
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #14 of 15 Old 09-10-2013, 11:04 AM Thread Starter
CJ7KAHUNA
Well I PM'd the guy on JU that is quoted above - he says that if its geared 4.10 or more then the ring gear being bigger it will obstruct the cross pin and that the carrier will have to be removed and the ring gear taken off. I am perfectly comfortable removing the cross bar and thrust block but I have no experience setting up gears so - there's that.
post #15 of 15 Old 09-10-2013, 11:26 AM
LumpyGrits
Pull the axles.
Unbolt the 4 bear'n cap bolts(mark the caps).
Jerk out the carrier, it should be under a preload. Don't loose the shims as they are on the outside of the carrier bearings. IF, you loose or mix up the shim pack, you are SCREWED.........
Witness mark the ring gear on the carrier. Remove r'gear.
Then when you reinstall, make sure you torque everdangthing to spec and use red loc-tite on the r'gear bolts.
It's not brain surgery.
LG
