Moser One Piece Axles - JeepForum.com
post #1 of 8 Old 08-31-2013, 02:34 PM Thread Starter
CJ7KAHUNA
Sold my old tires on CL and want to use the funds to pick up a set of Mosers for the AMC 20 in my 85 CJ7. Beings my budget is minimal - I was wondering if anyone knows who has the best deal on them shipping included. I didn't see'em on Q-tec which is where I usually shop due to the JF free shipping deal (which is awesome of them to do that for us) Anybody got a link?
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
post #2 of 8 Old 08-31-2013, 03:11 PM
I6CJ7
I think i got mine from summit racing. They ship from the manufacturer and take a little longer. Or i ordered them directly from Moser, can't remember. And they're still sitting in the bixes 6 months later uninstalled... Lol
I6CJ7 is offline
post #3 of 8 Old 08-31-2013, 04:12 PM
holliewood61
1981 CJ7
I got a set about a month ago from summit. $285 for the mosers I believe
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #4 of 8 Old 08-31-2013, 04:38 PM Thread Starter
CJ7KAHUNA
Yep - Summit looks like the deal so far. No shipping and $285
post #5 of 8 Old 08-31-2013, 04:45 PM
holliewood61
1981 CJ7
Jegs has them for $285 as well but I'm not sure on shipping with them
08 WK bone stock
00 WJ daily driver
60 CJ5 tore down
post #6 of 8 Old 09-09-2013, 10:24 PM Thread Starter
CJ7KAHUNA
Well I pulled the trigger and ordered them from Jegs - Same price as Summit and free shipping as well. Both places stated they were out of stock but Jegs had a ship date 4 days earlier so they got my $$$$.
Couple of install related questions - Would like to hear what bearing grease and differential fluid/lube you guys recommend (I'm planning on having to remove the thrust block). I already have a set of shoes and replacement hardware for the rear brakes since I'll already be in there. Should I consider replacing the wheel cylinders as well? No issues with the ones I have now - they work fine and don't leak but they are 28 years old.
post #7 of 8 Old 09-10-2013, 04:09 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
you have to crack the brake line to pull the axle anyway....... I went ahead and did both sides of my brake lines while there as well.....I use lucas super sticky red grease and standard 80/90.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #8 of 8 Old 09-10-2013, 10:47 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by CJ7KAHUNA View Post
..Should I consider replacing the wheel cylinders as well? No issues with the ones I have now - they work fine and don't leak but they are 28 years old.
For around $10 each for new ones, I would replace them while you have everything apart. if they come out without problems, then the swap adds maybe 10 minutes per side. Be sure to buy a quart or two of brake fluid for when you bleed the brakes.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
