Moser AMC 20 upgrade question - JeepForum.com
post #1 of 5 Old 12-02-2013, 02:52 PM Thread Starter
atxjeep79
1979 CJ7
I am installing the Moser one piece kit in my 79 CJ7 and so far so good was able to get everything out, but my question is about the bearing clearance.
So I put in inner seals and the press ring and went to test fit the bearing for clearance and Moser recommends that it be within .02-.08 and on the driver side I am within but barely .075 and on the passenger side it is over by about .025 reading .105
Moser recommends that you grind the press ring for clearance so should I get new spacer rings and inner seals from moser(since I have a feeling I will destroy the old ones in the removal process) and take them to a machine shop or can I use shims like the ones installed on the driver side originally to gain the required clearance.
I know there are a million threads on this just wanted an opinion on using shims instead of grinding the spacer ring is it the same difference?
atxjeep79 is offline
post #2 of 5 Old 12-02-2013, 03:13 PM
LumpyGrits
Make sure the inner seal is at the same depth on both sides.
Make sure the axle bearing is set up against the 'shoulder/stop' on the axle.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 5 Old 12-02-2013, 03:30 PM
skizriz
1978 CJ7
I have heard of people using the original shims instead of grinding the spacers.
Other than being more surfaces to seal, i dont see Why it would be a problem.
Mine squeeked by without needing any grinding, so I cant say from personal experience either way.
Sent from my HTC One SV using JeepForum
skizriz is online now
post #4 of 5 Old 12-03-2013, 07:30 PM Thread Starter
atxjeep79
1979 CJ7
Thanks guys I think that I will order some more spacers and have them ground down just to be on the safe side
post #5 of 5 Old 12-03-2013, 11:05 PM
big_o_tom
1978 CJ7
I used stock axle shims to get the perfect "preload" on the model 20 that was in my jeep when I bought it. Ended up swapping the rear end for a dana 44, but the shims did just fine.
big_o_tom is offline
