Moroso Coil wire too short? - JeepForum.com
post #1 of 2 Old 02-11-2013, 12:03 PM Thread Starter
Palmetto
Palmetto's Avatar
1981 CJ7
I just bought a set of Moroso plug wires and the coil wire is too short.
Anyone know what might be the problem?
This is the set I bought.
http://www.moroso.com/catalog/catego...?catcode=39009
I ordered them from Summit.
I have a 360, standard distributor and ignition coil. CJ-7.
The wire could use another 2-3" to really be the right length.
I'll try and take a pic of my issue tonight.
ΜΟΛΩΝ ΛΑΒΕ!
Do your duty in all things. You cannot do more, you should never wish to do less.
Robert E. Lee
Groups
Originally Posted by DiabloYJ View Post
It's a Jeep thing, I don't even understand it sometimes.
1981 CJ-7, AMC 360 bored .30 over, Edelbrock Intake, Edelbrock Cam, Edelbrock Double Roller Timing Chain, Holly 650 truck avenger carb, Flowcooler water pump. '97 Dodge 4wd Std NV4500. D300 Twin Sticked. Corbeau Seats, Custom Dash with Autometer guages, Electronic Speedo, all stainless hardware, Outlaw II Wheels, BFG AT 33" Tires, Flex-A-Lite Dual Electric Fan, AGR steering box, Borgeson steering shaft, ididit tilt column, Mean Green Starter, Tuffy console, poly gas tank, handmade rear bumper, cheap radio and speakers.
2000 XJ - HO 4.0L, 245/75R16 Goodyear Wrangler Duratracs. PSC gearbox. IRO Double Shear Trackbar. New headliner. IRO Hack & Tap SYE. IRO adjustable UCA & LCA, RE 3.5" lift, Bilstein 5100 shocks, JKS Quick Disconnects. Future mod: OTK steering, lockers, FIPK, rock sliders, JCR Bumpers, rear storage, high pinion rear (3.55), frame reinforcement, hood louvers, rack lighting.
Palmetto is offline
post #2 of 2 Old 02-11-2013, 02:32 PM
jumbojeepman
1976 CJ7
Perhaps someone moved the coil to the wrong location in the past. Also, it might not be turned the correct direction.
jumbojeepman is offline
