MORE V8 mount guys... how far forward did you mount your frame brackets? - JeepForum.com
post #1 of 12 Old 05-05-2008, 12:13 PM Thread Starter
Aaroneous
1983 CJ7
I'm just getting ready to drop an AMC 360 in my '83 CJ7 and I did a test run last night to check alignment and it looked like I was going to need a pretty magical shoehorn to make that engine fit in. The back of the block was hitting the firewall and the engine mount was a good 2 inches from the center of the bushing. I had the mounts centered on the 6 holes (i.e. - bolts in the 4 corner holes), but I suppose I could try to move the mount 1 row of holes forward to push the engine forward.
If you are running this setup with your V8 where did you mount yours? How much room SHOULD there be between the block and the firewall?
Aaroneous is offline
post #2 of 12 Old 05-05-2008, 03:35 PM
Bard
Well I am Chevy so I can't really help, but there is a sticky about the AMC swap right above where you post. Might find what you need in there. Luv the V-8's
http://www.jeepforum.com/forum/f8/official-amc-v8-swap-thread-377983/
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 12 Old 05-05-2008, 03:45 PM
turnabout
1974 CJ5
I would say 3/4 -1 inch space at a glance. Take into account mine came installed by the PO and I have an intermediate CJ so I can't speak for the mounts.
The two best off-road vehicles in the world -- the Jeep CJ and rental cars.
turnabout is offline
post #4 of 12 Old 05-05-2008, 04:23 PM Thread Starter
Aaroneous
1983 CJ7
Thanks! I actually read that a few times while researching the swap. Very helpful, but this was a little more specific I think.
3/4 - 1 inch farther forward than the stock holes? Not sure I'm following what you are saying. Can you give me a reference point?
I'll be making sure the frame mounts are on the correct side (I'm SURE I did it correctly), and I'll try installing the engine at a different angle and see if that helps at all.
Thanks!
post #5 of 12 Old 05-05-2008, 04:36 PM
turnabout
1974 CJ5
Actually I was hasty in my post -- I meant 3/4 - 1 inch space between the bell housing and the firewall.
post #6 of 12 Old 05-05-2008, 05:07 PM
fluid_grind
fluid_grind's Avatar
1978 CJ5
I used the original mounting holes with the M.O.R.E. mounts when swapping in my 360 into my cj5. I have around 3/4" clearance.
Black 94 YJ, 4.0 L, 5 speed, RE 2.5 Standard Lift, 2" BL, 32 X 11.5 Mud Rovers on Black 8 X 15 steel Pacers, Warn winch.
78 CJ5, rebuilt 360, with T-18 Transmission, D20 transfer with teralow, Dana 44s with OX lockers front and back, 4.88 gearing, SOA with RE 1.5 lift springs and high steer, 37x13 Boggers on 16" MT Classics : Project Jeep
fluid_grind is offline
post #7 of 12 Old 05-05-2008, 07:46 PM
bdmonist
WTF is that?
bdmonist's Avatar
If you have tried to mount it and know how much more you need to make it clear, just move it forward that amount! I have a SBC and have only 1/2 inch between the distributor and firewall, a little close for my comfort. Also, is there any disadvantage to moving it as far forward as possible - better driveshaft angles - Just let the fan clearance be your guide and push it up as far as you can.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #8 of 12 Old 05-05-2008, 11:30 PM
lepurcon
1983 CJ7
just got done with my 83 cj7 swap with a 360 and used the more mounts and factory holes. Its was tight but went in just fine. If you move the mounts I have heard of guys running into driveline issues, but thats just my two cents.
I dont know why the guy that sold me this didnt tell me that Priceless meant this......
lepurcon is offline
post #9 of 12 Old 05-06-2008, 09:29 AM Thread Starter
Aaroneous
1983 CJ7
Did you mount your frame mounts, then put the brackets on the engine, then drop it in? What order worked best for you? I'm trying a few different things - hard part is trying to get the engine to sit straight side to side on the lift.
post #10 of 12 Old 05-06-2008, 09:45 AM
fuzz401
1978 CJ7
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #11 of 12 Old 05-06-2008, 02:24 PM
COBRA5LADDICT
Make sure you dont have the left mount swapped for the right, i did that once and nothing really wanted to line up.
COBRA5LADDICT is offline
post #12 of 12 Old 05-06-2008, 07:10 PM
lepurcon
1983 CJ7
I mounted to the frame and the block seperate and then ligned them up with each other and slid the bolt through the bracket. Now it wasnt as easy as it sounds though it took my wife and I about 4 hours of in and out and in and out.
lepurcon is offline
Stock Motor Mount Frame Brackets 243 Jeep CJ Forum 6 02-02-2009 08:41 PM
Motor Mount Brackets 2.5 to 4.0 Swap joemac421 Jeep CJ Forum 5 09-23-2008 12:18 PM
motor mount engine brackets Andy5150 Jeep CJ Forum 5 11-04-2007 10:25 AM
258 motor mount brackets AMC Power Jeep CJ Forum 2 10-10-2006 10:51 AM
Need spindle mount CJ disc brake brackets jeepmor Jeep CJ Forum 0 09-15-2004 12:27 PM
