more starter problems - JeepForum.com
post #1 of 10 Old 06-16-2012, 05:45 PM Thread Starter
rtormet
I was having a lot of starter problems when i bought my 84 CJ7 about a month ago. It sounded like the bendix gear was getting in a bind or something on the way back into the at rest position. I tried a few starter modification techniques but nothing seemed to work. The Ring Gear didnt look insanely bad but I was beginning to think I might need to replace it.
I removed the trans and transfer case. Then i removed the bell housing and found that the holes for the starter were deformed and elongated.
So i replaced the bell housing - replaced the ring gear - along with the clutch and pressure plate just for good measure. I replaced the starter again with a Napa Premium starter.
When everything went back together I started it back up and it was even worse than before. It was grinding from the start. Same sound - but the whole time the bendix gear was activated it made a terrible grinding sound.
Im stuck. Dont know what to do. I have almost completed the mechanical section of my rebuild but this is holding me back.
Please Help.
rtormet is offline
post #2 of 10 Old 06-16-2012, 06:02 PM
86cj74.2L
86cj74.2L's Avatar
Since it was you who pulled the bell housing off do you remember if there were dowels sticking out of the block in the lower corners?
If there not their you need to put some in.
86cj74.2L is offline
post #3 of 10 Old 06-17-2012, 08:09 PM Thread Starter
rtormet
I dont remember them specifically - what is the purpose of said dowels?
rtormet is offline
post #4 of 10 Old 06-17-2012, 08:16 PM Thread Starter
rtormet
Would you have a picture of the block with the dowels in there? Without knowing what to look for I am not sure if they were there.
rtormet is offline
post #5 of 10 Old 06-17-2012, 08:23 PM
86cj74.2L
86cj74.2L's Avatar
They are hollow round pins stuck in the engine block at the lower 2 outboard bell housing bolt holes.
If there were not 2 round hollow pins sticking out you need them.
I don't have a parts diagram. But I got mine from the dealer. And saw them on the drawing.
post #6 of 10 Old 06-17-2012, 08:35 PM Thread Starter
rtormet
OK my block definitely had both dowel pins to keep it aligned. My dad was helping me put it together and remembers them both being there
rtormet is offline
post #7 of 10 Old 06-17-2012, 08:36 PM
86cj74.2L
86cj74.2L's Avatar
Item 35.
post #8 of 10 Old 06-17-2012, 08:42 PM
86cj74.2L
86cj74.2L's Avatar
There are plenty of previous owner syndromes on this forum and the havoc they caused.....
I don't know if AMC always used the ford starter on the big 6. but if the flywheel is the correct year as well as the bell housing and starter........you get my point. Something is wrong or has been changed.
post #9 of 10 Old 06-17-2012, 11:16 PM
jurgen24
Also had starter issues when I 1st got my Jeep, a real PITA! High pitch grinding noise and difficult to start. My starters used to break, e.g. nose cone bust off, gear broke. In the end I replaced the ring gear, even though the previous one didn't look to bad. Seems like once it starts grinding the ring gear does not last long.
If you have the alignment dowels and you've already replaced the ring gear, then the only thing that comes to mind is that starter solenoid and/or wiring to starter, maybe there is not enough juice to fully engage the gear. Try painting the starter gear, and then do a start. Pull the starter, and see how much contact you are getting.
jurgen24 is offline
post #10 of 10 Old 06-18-2012, 01:00 AM
BagusJeep
1981 CJ7
Always worth checking your dimensions match up.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
starter
79 CJ7 Starter Problems TsCJ779 Jeep CJ Forum 4 06-01-2015 07:31 AM
Starter problems - starter stays engaged KGBnumber1 Jeep CJ Forum 9 11-13-2014 12:10 PM
Starter Problems scrambledjeeper Jeep CJ Forum 0 12-10-2011 08:47 PM
Starter problems ctrim78 Jeep CJ Forum 10 06-26-2011 12:45 PM
Starter problems? mideerhunter Jeep CJ Forum 7 06-23-2011 04:47 PM
