More on Frame Clean up? - JeepForum.com
post #1 of 3 Old 10-03-2002, 08:03 AM Thread Starter
DaveFL
DaveFL's Avatar
Contacted the guys at POR 15 found that in order to use this stuff I need to take frame down to bare metal.
1/4 of the frame has been stripped down, but was trying to prevent stripping entire frame. Engine and transmisson are still mounted and I have no way to move frame for sandblasting.
At this point I have 2 options I guess.
Sand and grind the entire frame by hand or is there a better solution?
Find a different frame paint that does not require bare metal to bond too that will prevent surface rust spots from reforming, any ideas?
Ive been using a grinder with 120 grit soft abbrasive pads to strip now. Its working pretty good although hard to get in some tight places, and the pads last for about 2 feet of frame each so It might get costly this way as well. Any other suggestions for stripping?
Thanks
Dave
DaveFL is offline
post #2 of 3 Old 10-03-2002, 04:47 PM
jadams68
jadams68's Avatar
That guy is smoking crack.
Do your best to clean it up with a grinder, wire wheel, wire brush, whatever.... and then coat it....
Don't sweat it.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 3 Old 10-04-2002, 07:10 AM Thread Starter
DaveFL
DaveFL's Avatar
Okay so the POR 15 will adhere to old frame paint if its cleaned up? Anyone else try this?
I guess its worth a shot anyhow.
Thanks
Dave
DaveFL is offline
back half of cj5 frame to replace rotted cj7 frame? jedsled Jeep CJ Forum 8 05-30-2011 05:11 AM
cj frame cracked....replacment frame or 1 ton frame for cj neatocj Jeep CJ Forum 17 12-03-2009 08:44 PM
Frame Repair - cutting frame open to remove rust? Bell-Vegas Jeep CJ Forum 4 04-21-2009 10:44 PM
Rear shackle to frame bolts, how do you get in the frame? Blthomas Jeep CJ Forum 5 02-19-2009 07:26 PM
Question about frame clean-up??? tgc79cj5 Jeep CJ Forum 9 10-14-2002 11:53 AM
