More 360 questions - JeepForum.com
post #1 of 3 Old 03-12-2002, 05:44 PM Thread Starter
Rotorhead
1982 CJ7
Post More 360 questions
Hey thanks for the input on the T5! Now for a few more questions. I have a 77 cherokee with a 360/th400. I want to put the 360 in my 258/t5 powered 82 cj7 and keep the t5. I know I need new motor mounts, exhaust, radiator, etc. What is involved with converting an engine with an automatic to one with a manual trans? I think that the bellhousings are both the same so there shouldnt be a problem there. What about the flywheel and input shaft on the trans? Any help is appreciated!
82 CJ-7- sold 😬
98 Grand Cherokee 5.9L
Rotorhead is offline
post #2 of 3 Old 03-12-2002, 08:34 PM
BillR
BillR's Avatar
Post
There's a VERY thin bushing in the back of the crank that's used to center the torque converter on your TH-400. The bushing is HARD to see, but has to be removed to install the proper pilot bushing. Advance Adapters has the right bushings.
Also, I'd re-think using a T-5 behind even a mild 360. It won't last long!
You'll need to get a 360-balanced flywheel, too.
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #3 of 3 Old 03-18-2002, 01:18 PM
boredstiff
Post
Make sure your bell housing has the opening for the clutch linkage. In addition, I would change tranny's... that isn't going to last long. Your right about the engine mounts, exhaust, rad, and you'll need the flywheel which is hard to find for less than $150 to $200 bucks. Do you have the correct brackets for the clutch in the cab?
boredstiff is offline
Mod questions McJeepster Jeep CJ Forum 10 09-12-2008 06:57 AM
Couple more questions for the pre-start rundown, ignition, carb, misc questions..... Blthomas Jeep CJ Forum 3 07-01-2008 05:56 AM
First CJ questions jmhat98 Jeep CJ Forum 6 03-07-2007 10:29 PM
cj5 2 questions rmballou Jeep CJ Forum 5 02-13-2007 10:48 AM
CJ5, a few questions. Brandon11130 Jeep CJ Forum 12 09-29-2005 01:42 PM
