mopar mpi upgrade question. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > mopar mpi upgrade question.
Unread 12-02-2015, 11:38 AM   #1
hunterstroble
I have searched and can not find anything, I could call HESCO but thought I'd ask and get advice from people who have done this upgrade. I have an 85 cj7 with power brakes. My questions are:
- I have Clifford headers, will these work with the swap? I know I have to weld in an 02 sensor bung.
- Will the intake assembley clear my brake booster? Right now I have a Clifford intake with a holley 390 and it's really close.
- Any issues with my valve cover? I have a Clifford aluminum one. With a push in breather in the front and pcv in the rear. Any issues with using the valve cover?
thanks!
hunterstroble is offline   Reply With Quote Quick reply to this message
Unread 12-02-2015, 11:40 AM   #2
hunterstroble
Also none of the emission hoses or canister is there. These were gone when I got the jeep. Thanks.
Unread 12-02-2015, 08:41 PM   #3
Kstein
I was able to install a Borla header, but it required some modification to the power steering pump bracket.
Also, no power brakes, so can't speak for that.
TAMC85 CJ7
Still Original: Tub, Rollbar; Frame; 258 Block; T176; DANA300; Steering; DANA30; AMC20; Drive Shafts; Wheels; Tank; Altenator; Fan; Frt Bumper; Speedo; Heater Box; Spare Carrier; Seat risers
Replaced: Radiator; Valve Cover; Clutch linkage; Taillights; Frt Brake Calipers; Fuel, Tmp, and Oil Pressure Gauges; Exhaust line; Seat Belts; Paint
Mods: Mopar MPI(in progress); 4.0 Al Cylinder Head; OME YJ Suspension; MC Seats; Tub liner; 31" Tires
Kstein is offline   Reply With Quote Quick reply to this message
Unread 12-03-2015, 10:07 AM   #4
hunterstroble
Thanks for the reply.
Unread 12-07-2015, 10:04 AM   #5
hunterstroble
any one else?
Unread 12-07-2015, 01:42 PM   #6
Stumblebum
1982 CJ7
The intake manifold clears the brake booster by about an inch. However, the Manifold Air Temp (MAT) sensor attaches to the manifold just below the booster. The top of the sensor clears the booster by about 1/4". When you need to replace motor mounts in the future, you'll need to either remove or relocate the sensor to avoid crushing the sensor. With multiple plugs and sensors on the manifold, you can use the locations that work best for you.
Stumblebum is online now   Reply With Quote Quick reply to this message
Unread 12-08-2015, 10:59 AM   #7
hunterstroble
OK, thanks!
