MOPAR MPFI kit question - JeepForum.com
post #1 of 17 Old 03-12-2008, 07:53 PM Thread Starter
OSUAV8R
I was wondering why you are told to use 92 octane when you install the Mopar kit.
Anyone know why?
Thanks
OSUAV8R is offline
post #2 of 17 Old 03-13-2008, 02:30 PM Thread Starter
OSUAV8R
nobody as installed the kit?
Nobody has installed the Mopar kit?
Please.. any help would be great
gas is to expensive to be using a higher grade if it is not required
Nathan
OSUAV8R is offline
post #3 of 17 Old 03-13-2008, 08:11 PM
Fourtrail
1974 CJ6
Most likely because of the timing advance w/ the mopar computer. Keeps motor from pinging. Same thing if you run a high performance computer.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #4 of 17 Old 03-14-2008, 03:24 PM Thread Starter
OSUAV8R
So your saying I really do need the high octane fuel? Even though the engine is not a high compression engine
OSUAV8R is offline
post #5 of 17 Old 03-14-2008, 04:30 PM
roundlitefan
Well, just from this married guy's point of view, if I could afford to be putting a Matkins frame under my Jeep, and a $3000 MPFI system on it, the last thing I would be worried about is 92 octane gas.
I would pay that extra $.20/gal ($3/tank) and drive away from the pump with a big fat grin on my face.
Just my $.02
roundlitefan is offline
post #6 of 17 Old 03-15-2008, 07:31 AM
HighCountry
I have always subscribed to Roundlite's point of view! More so now than ever, the percentage more per tank with $3.20 fuel versus $3.45 is tiny. $3.75 on a 15 gallon fill up that is costing $50.00 is too insignificant to worry with...
Bruce
HighCountry is offline
post #7 of 17 Old 03-15-2008, 06:42 PM Thread Starter
OSUAV8R
Roundlite. When I bought the Mopar kit it was $1600 and the frame cost a lot less then a new jeep. Trust me, I am not doing the frame swap for fun...although I hope it will be
and second. $3.75 per tank over the course of a year is not an insignificant amount of money
OSUAV8R is offline
post #8 of 17 Old 03-27-2008, 08:03 PM Thread Starter
OSUAV8R
Does anyone here have the mopar kit, or is it just me?
OSUAV8R is offline
post #9 of 17 Old 03-27-2008, 08:37 PM
tsjeepcj
1981 CJ7
i've got the mopar kit and run premium in it. i bought it used from a buddy, and when we swapped it in complete with his motor, i had to run the rest of a tank of 87 through it. it didn't like it very much. sorry i can't help as to why it needs 93...the manual only says to run 93 if you get spark knock...btw, i love the mopar kit. it starts every time, runs good, and does great offroad....
81 cj7 on 37's...
tsjeepcj is offline
post #10 of 17 Old 03-27-2008, 10:15 PM
73jeep
1973 CJ5
Try 87 and if it doesn't ping your fine, if it does retard the timing a little till it doesn't anymore, if you want to run 87 so much. Im guessing there is no knock sensor on this setup.
73jeep is offline
post #11 of 17 Old 03-28-2008, 12:41 AM
CompGuru
CompGuru's Avatar
1983 CJ7
I have an 1983 CJ7 with the 258 and I run 91. I found that the additional MPG overcomes the measly 0.20 cost difference. Also helps with highway speeds. Im sure it's different for everyone's Jeeps. I believe that Mr. Romain runs premium as well. As for the MOPAR kit I don't have one and I personnaly think that $2500 is highway robbery. For that much you could put in a better, newer engine or just do a 4.0L swap and get the same effect.
Dustin
1983 Jeep CJ7 White
Team Rush, Halogen Headlights, Nutter Bypass, more to come...
"There is no mechanical problem too tough that cannot be fixed by brute strength and ignorance."
"Remember, Amateurs built the Ark, Professionals built the Titanic."
CompGuru is offline
post #12 of 17 Old 03-28-2008, 05:44 PM
Rob55
I have the MPI kit and like it a lot. I have run 89 in it and it did ok, but it prefers the 91/92 available here (CA). You can play with the timing a bit to smooth it out for lower octane but the performance suffers., but I have just gone with running the 91/92 all the time. The MPI kit is a little expensive but you don't see a lot of posts asking for help with it like the carb and TPI solutions (both of which work great if you know what you are doing for maint and install). I have run it at sea level one day and at 7000 ft the next, no problems.
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back....
Rob55 is offline
post #13 of 17 Old 05-16-2008, 07:36 AM Thread Starter
OSUAV8R
Thanks, I run 89 and it seems fine, I just want to make sure I am not causing long term damage
OSUAV8R is offline
post #14 of 17 Old 05-16-2008, 05:04 PM
sed437
I don't know why, but I put the kit on my 85 CJ7 and use the cheapest 87 octane I can find and it runs great.
sed437 is offline
post #15 of 17 Old 05-18-2008, 09:10 AM Thread Starter
OSUAV8R
thanks, I use 89 and it seems very happy, I just wondered why they say 93.. there is no point in using a higher octane unless for a real reason..
OSUAV8R is offline
Mopar MPFI fuel line question on 85 CJ OSUAV8R Jeep CJ Forum 3 07-27-2008 02:14 PM
mopar m44 swap question spk454 Jeep CJ Forum 1 06-20-2008 11:22 AM
258 MPFI mod gumby Jeep CJ Forum 2 05-24-2006 11:05 AM
Mopar MPI qjeep Jeep CJ Forum 1 11-03-2005 06:55 AM
mopar mpi bseely Jeep CJ Forum 4 06-14-2003 01:02 PM
