Mopar MPFI kit engine compartment pics - Page 2 - JeepForum.com
post #16 of 19 Old 09-12-2011, 09:20 AM
PERK
Fredrok, I agree with you, there is a wealth of information on OBD2. but, the kit as supplied is OBD 1 based on a '94 4.0
PERK is offline
post #17 of 19 Old 09-12-2011, 10:31 AM
fredrok
Yes, it is an OBD I system and no, you cannot generally adjust timing. However, you CAN adjust timing with a DRB II diagnostic computer (scanner). Not to be confused with OBD II. 2 entirely different animals. I have one. I have advanced my timing 2 degrees from stock setting which is generally retarded 6 degrees by default.
Pics of the injectors I was speaking of earlier and a readout of the DRB scanner connected to my MPFI kit.
Also, as an alternative, because the DRB scanners are hard to come by, you can call Lee or Bernie at Hesco and they will burn you a Unichip to your needs with free tuning programs to download and program until it's fine tuned. They can change fuel and spark maps among other parameters.
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
post #18 of 19 Old 09-12-2011, 05:56 PM
tombstne
1982 CJ7
Hey Fredrok, did you have MPI with a 4.2 head then converted to 4.0 head?
I have the 4.2 w/MPI and debating if I want the 4.0 head? Noticeable power? 87 oct gas is a plus.
tombstne is offline
post #19 of 19 Old 09-12-2011, 06:29 PM
fredrok
I did the head and FI kit at the same time. It was also soon after I moved from sea level to 7,400ft so really have no comparison. Sorry.
I built the engine years ago, bored .020 over and milled the deck so my compression ratio was already higher. With the smaller combustion chambers on my 4.0 head, I'm just shy of 10:1 which would be more than a stock configuration. I cannot run less than 91 and that's the highest you can find where I am (altitude). I try like hell to fuel with non-ethanol when able and I occasionally had ping even with the 4.0 head under load going up hill on warmer days (aggravated by the more aggressive camshaft). That all went away when I swapped injectors.
fredrok is offline
Engine Compartment Help! Nelson Jeep CJ Forum 0 03-30-2010 01:39 PM
Engine compartment pics ryandelany Jeep CJ Forum 14 09-08-2008 12:18 AM
Mopar MPFI fuel line question on 85 CJ OSUAV8R Jeep CJ Forum 3 07-27-2008 02:14 PM
MOPAR MPFI kit question OSUAV8R Jeep CJ Forum 16 05-30-2008 08:27 AM
how big 350 engine compartment? geepvehicles Jeep CJ Forum 1 11-02-2005 06:37 AM
