Mopar MPFI fuel line question on 85 CJ - JeepForum.com
post #1 of 4 Old 07-25-2008, 04:09 PM Thread Starter
OSUAV8R
Hey Everyone. I am knee deep in my frame swap and the more I take apart the more I see needs to be replaced. I was pulling the original fuel lines out and they dont appear to be in great shape so I figured i should just replace them.
Question 1) the prebent lines are $99 at 4WD and there are three (I think). Is there another option?
Question 2) I have the Mopar kit installed and I know they changed some of the fuel lines. Does anyone else have the Mopar kit and know where I can get those lines? I installed it over 10 years ago.. and I forgot what it involved.. so I guess question 3 is.. if I have to get the prebent lines... and I wasting money if I have to cut them... is it hard to bend fuel line?
Thanks
Any pics or diagrams would be great
Nathan
OSUAV8R is offline
post #2 of 4 Old 07-26-2008, 12:45 AM
coas
Just get a tubing bender, a tubing cutter and follow the stock line bending. Did that a few month ago with the tub on, not a pleasant job but with the tub off it's should be easy. the bending part was fan, installing it wasn't.
Run 3/8 line from the fuel tank to the fuel rail and 5/16 for the return line. both on the driver side.
84 CJ7 , Dana 44 rear D30 front, 258, 4.0 head, MPFI, e-fans, T176, Dana 300, 31x10.5x15 and Mustang hydroboost.
My esnips folders:
coas is offline
post #3 of 4 Old 07-26-2008, 01:52 PM
Rob55
Agree with COAS, cheaper and easier to bend yourself. If you really want to buy prebent try HESCO. They make (and install) the MPI kits. Hope that helps.
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back....
Rob55 is offline
post #4 of 4 Old 07-27-2008, 02:14 PM Thread Starter
OSUAV8R
thanks guys, where do you buy unbent fuel line? is there a tool to make the nipple style end? or is a good hose clamp enough?
OSUAV8R is offline
Fuel Line Question... Eagle2 Jeep CJ Forum 1 03-15-2009 11:28 AM
MOPAR MPFI kit question OSUAV8R Jeep CJ Forum 16 05-30-2008 08:27 AM
Fuel line question CompGuru Jeep CJ Forum 70 01-28-2008 08:01 PM
Dumb Brake Line and Fuel Line Question GroundUpCJ7 Jeep CJ Forum 3 04-02-2007 06:01 PM
Fuel line question(different than below). TheJunkMan2005 Jeep CJ Forum 2 05-27-2005 06:27 AM
