Just thought I would give back a little after all the great tips I have got from this site over the years.
I did the Mopar MPI kit a few months back. Getting ready for the smog guys here in CA and found out that I have to have the check engine light hooked up and functional for everything to be on the up and up. I like to keep everything on the jeep looking some what original so I wanted a light that would meet that goal.
Here is what I ended up doing. Went to the local Jeep junkyard and grabbed a couple of dash lights. Removed the silver bezel, took out the vinyl lettering and replaced with a piece I printed out at home and Covered it with a little clear mylar.
As for placement and install. I decided the spot over the drivers side speaker grille would work well. I cut the slot with a dremel and cut off wheel.
The end result is clean and somewhat stock looking so if you are in need of a Check engine light try this.
