Model 20 Fluid Change Question - JeepForum.com
post #1 of 6 Old 01-08-2010, 03:44 PM Thread Starter
Pog
Pog's Avatar
Go on and call me lazy, but is it possible to just pump the fluid out of the Model 20 pumpkin through the fill hole?
All I want to do is change the fluid which I know is about a 1.5 years old. So, why bother with the PITA Torx bolts, gasket, etc. if I can help it just to refresh the fluid. Just curious if anybody has done this.
Thanks
Pog is offline
post #2 of 6 Old 01-08-2010, 03:48 PM
Fjguercio
1978 CJ7
why not? I would still warm it up so it flows of the parts to the bottom better and flows in pump better than winter temps.
They also have after market covers that have a drain plug and are HD. I may get one of those some day. There are also gaskets you can reuse, they cost about $15-20 and summit or quadratec had them.
Fjguercio is offline
post #3 of 6 Old 01-08-2010, 03:53 PM
CSP
You could, but then you couldn't inspect the internals for any damage that may or may not be present.
If you do pop the cover, replace the torx head bolts with hex heads so you eliminate that problem in the future. Permatex "The Right Stuff" beats any gasket that I've ever used.
CSP is offline
post #4 of 6 Old 01-08-2010, 03:57 PM Thread Starter
Pog
Pog's Avatar
Definitely need to warm up the fluid right now. Geez it's cold outside. I'm web-wheelin' today.
If it's plausible, I just need to see if I can find a pump that will do it. I think I saw one at the local auto parts house a while back. I had seen the reusable gaskets for most of the Dana axles, but not the AMC 20. I'll look at Summit to see.
Thanks
Pog is offline
post #5 of 6 Old 01-08-2010, 04:03 PM Thread Starter
Pog
Pog's Avatar
I hear ya. I did that about a year and a half ago when I changed the fluid and gasket. Eveything was fine and my CJ has pretty much just been garaged or on the street for the weekend. No severe duty was done enough to make me worry otherwise. Heck, the fluid in it probably still good. I just got a very good deal from a friend on a case of Royal Purple and figured I would change everything out for the heck of it.
I have also heard good things about "The Right Stuff."
Thanks
Pog is offline
post #6 of 6 Old 01-08-2010, 04:08 PM
77j20
1977 J-Series Truck
Thats all we do at work when we do a differential service. Unfortunately quick lube shops don't have the time to take covers off and re-install them, it just wouldn't be worth it. We use a pump to suck all of the old fluid out on diffs that don't have drain plugs. We do pump new fluid in and suck it out so it gets somewhat of a flush.
1977 J-20 TeamRushed AMC 401, TH400, D44 front, D60 rear, 33x12.50R16.5 Mud Terrains, SOA, rear shackle flip.
77j20 is offline
Fluid Change MoC Jeep CJ Forum 1 07-10-2009 07:13 PM
CJ-7 Transmission Fluid Change newjeepowner Jeep CJ Forum 3 12-06-2008 11:44 AM
transmission fluid change-CJ newjeepowner Jeep CJ Forum 6 12-05-2008 04:19 PM
Fluid Change Carmell CJ Jeep CJ Forum 1 01-20-2007 05:17 PM
Tranny Fluid Change GabrielCJ7 Jeep CJ Forum 1 07-31-2002 09:27 PM
