Model 20 Axle Question - JeepForum.com
post #1 of 3 Old 01-16-2002, 08:38 PM Thread Starter
TG CJ7
Post Model 20 Axle Question
Iím wondering how you can tell if youíve spun the two piece axles. I've bought an 84 CJ7 a while back and when I bought it the guy told me that it had a problem with the rearend. One wheel will lock up at random. It didnít do it all the time. Now Iíve got it torn down to the frame because Iím replacing the tub, and Iím not even sure if itís the same wheel every time. Iíve only driven it three or four times so thatís all the information I have. I should be done with the tub this weekend, so the rearend is my next project. If itís not the axles, what could it be?
1979 CJ7 Renegade 304, 3spd, 2.5 BDS lift, Hedman headers.
Check it out
TG CJ7 is offline
post #2 of 3 Old 01-16-2002, 10:11 PM
bigbovine
Post
This is how I tested mine before taking it apart. I put my jeep in 1st gear held down the brake and let out on clutch. The rear wheel just sort of wobbled around while I sat still going nowhere. The other way since you are already down, take wheel off of both sides and inspect the assymbly. Good luck!
bigbovine is offline
post #3 of 3 Old 01-21-2002, 01:36 PM
timber
Post
I had the same problem with a Dana 44... Just drivin along and one wheel would lock up..
I finally fixed by rebuilding the brake cylinders...
You may want to also pull the rear diff cover off to inspect the ring and pinion. Make sure there isn't chunks of metal floating around in there.
I seriously doubt the you have broken axle for it to lockup like that it would have to break at the spline (the diff end) The 20's ussualy break on the wheel side (spin the hub) when that happens you can generaly jack it up and pull the wheel and hub completly off the axle.. (They generaly just fall off when it happens)
One thing to inspect before you go wheelin is the hub nut under the cap on the rear wheels. This bolt should have a cotter pin in it. Remove the pin and torque the bolt to 250ft lbs. and replace the cotter pin.. This is the main reason they is because that bolt gets looser than 250 ft lbs.
Hope that helps..
timber is offline
Model 20 rear axle one piece question garbageman Jeep CJ Forum 18 12-01-2009 10:29 PM
Model 20 rear axle, NEED HELP ! kyle1228 Jeep CJ Forum 13 10-17-2009 04:19 AM
Model 20 axle pinion question garbageman Jeep CJ Forum 17 01-23-2009 01:52 PM
Model 20 axle removal kavephish Jeep CJ Forum 5 03-24-2007 09:34 PM
Model 30 front axle and model 20 rear pinion oil seal? Paul M Jeep CJ Forum 6 06-08-2003 08:33 AM
