#1 | |
Mod questions
Will a early model 87 YJ roll bars fit the mounts for my 80 CJ7??
and also what are the pros and cons for spring over axle mounts??
Currently a twigdet learning the ways of the Gear Head PLEASE be patient... |
#2 |
axles
Will 1990 jeep axles work on my 84 cjy???
#3 |
No. the Front is drivers side drop you need passenger side
Bill H. - 1984 CJ-7 258 W/ Weber DGV 32-36, T5, Twin Stick Dana 300, Custom SOA, Dana 30/AMC 20 Locked 4.56's, 33" Swamper LTB's, York OBA, Custom bumpers, Homemade Swaybar Disconnects, Nutter Bypass, Team Rush http://www.schohariecountyjeepclub.com |
#4 |
since i've seen people interchange YJ and CJ bodies without too much trouble it would seem logical that the roll bar would also fit. only issue i could foresee would be the roll bar to windshield bar. you could either just leave the holes in the roll bar or drill your windshield frame to accept the YJ support bar.
'10 Wrangler Sport, soft top, hard doors, 23S package, Teraflex 2.5" spring lift, Spidertrax 1.5" wheel spacers '79 CJ-7 Renegade, 258 I6, T150, D20, D30/AMC20, 2.5in Rancho lift, 31x10.5 AT's, TeamRush upgrade, flush tail lights - Sold :'( |
#5 |
thanks for that i have been looking more and more at it and i think i am going to go for it cause i like the extra bar there.
#6 |
yes the yj bar will fit. i have one in my 79 cj i'm building my cage off of. i needed the drop to the floor of the tub. i also have a yj windshield on my cj. but i wouldn't trust the spreader bars with my life.
STEP 1: BUILD IT! STEP 2: BREAK IT! STEP 3: REPEAT!!!!! |
#7 |
does the YJ window fit the CJ body with no problems??
#8 |
I will bolt up but there is a difference in the defrost ducts.
CJ ducts run through the windshield, I don't think YJ ones do
#9 |
I heart bacon and pie
That is correct about the ducts. If you convert the YJ windshield to CJ type ducts, you will have to cover up two windshield wiper arm access holes in the YJ windshield.
#10 |
the CJ plates for the dash dash knobs will not line on the YJ windshield. they bolt up the same but are space to far to the outside. i just cut new L shaped pieces out of steel i had laying around. its a simple fix.
#11 |
alright thanks for the inputs
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
