MoC's Build Thread - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MoC's Build Thread
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-19-2011, 02:01 PM   #121
Skerr
Too funny MoC! Love it.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 02-19-2011, 02:07 PM   #122
Coiz
1979 CJ7
I'm digging all the fresh paint of the drive line parts. Nice work.
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 02-19-2011, 04:35 PM   #123
MoC
Thanks Mike! My big fear now is that by the time I get around to doing by body work and exterior paint the underside is going to be old and worn looking. Kind of like the carpet not matching the drapes.
Btw you should change you Avatar. It appears that all the cool kids are doing it today.
MoC is offline   Reply With Quote Quick reply to this message
Unread 02-19-2011, 05:15 PM   #124
Coiz
1979 CJ7
I've taken countless layers of dust and dirt off my finished chassis and it hasn't left the garage in over three years.
How's that for an avatar change? Since it seemed to be gun related, just a few beauties.
Mike
My build thread
Unread 02-20-2011, 05:25 PM   #125
MoC
Rear Main Seal RMS Replacement
Well played around a little more today while the kidos were sleeping. Mainly installing my RMS. I took a bunch of pictures, as I always seem do to, and lay it out step by step for future reference.
As far as sealant goes I used black permotex. I have also seen permotex #2 suggested as well. This first picture lays out exactly where the FSM says to install sealant. Blue lines in the picture on the lower section of the seal should have sealant top and bottom only where the blue lines run. The red lines represent the chamfered edges that get a small bead of sealant as well. The chamfered edge is the tiny 45 degree angled corner.
Started out by cleaning my block surface, already had the bearing cap cleaned up. As with anytime you use sealant the cleaner the better.
When cleaning the bearing cap also make sure to get all the old RMS material out of the grove. Mine was a bear to get out of both the top and bottom and left some material that needed cleaning.
The lower seal orientation is easy to figure out, it will only go in one way.
The grove on the upper seal should match the lower when installed so that it how you can determine its proper direction.
With all the other bearing caps still loose lightly oil the upper seal and slide it in to place.
I then coated the lower seal with some engine oil, slid it in to the lower bearing and applied RTV in the areas needed.
In doing all of this make sure not to get sealant on the mating surfaces of the bearing cap itself. Next I lightly oiled the the area of the crank where the bearing cap goes and installed the bearing cap.
Torqued all the bearing cap bolts down to 80 foot pounds and called it done.
Also got some more nuts and bolts cleaned and painted.
And that was my afternoon. Thanks for reading. Just waiting on a clutch spring, pressure plate bolts, and my new motor mounts which all should be here in the next few days. It will all start going back up soon!
Unread 02-20-2011, 05:57 PM   #126
Skerr
Nice write up. I've never done it but I would be confident now!
Kerrdog
Go Fish! <*////><
Unread 02-21-2011, 11:54 AM   #127
MoC
Thanks Scott.
Home for lunch and just saw the UPS truck coming down the street out the window. Got all happy and went and got my shoes. Came back and he was gone. Guess he was using my street as a short cut to somewhere else. Should have none better anyway my UPS guy usually does not come till late late afternoon.
Unread 02-21-2011, 11:54 PM   #128
MoC
Ahh crud, another 99 cent piece holding me up. Forgot about the clutch throw out lever ball!!! Going to call first thing in the am and see if anyone can get it here regular shipping by friday...
Unread 02-22-2011, 09:57 AM   #129
Trimble1
1983 CJ5
Excellent write up MoC. Great job so far.
'83 CJ5 4.2L D30 AMC20 D300
Stinking 2.73's 31" BFG's MC2100
Trimble1 is offline   Reply With Quote Quick reply to this message
Unread 02-24-2011, 04:46 PM   #130
MoC
So my 99 cent ball came in today and tomorrow I can start putting stuff back together!
Played for a few minutes today and removed the old pilot bearing by using the grease method. Packed it full of grease first.
Found a socket that fit perfectly and filled it with grease as well. Inserted it into the pilot bearing.
A few good whacks with a mallet and it started coming. Repacked it again and a few more whacks and it came right out.
So tomorrow if its not raining I plan on installing flywheel, clutch, and bellhouse. Maybe have time to install my new clutch linkage as well.
Unread 02-24-2011, 04:52 PM   #131
Eaglekeeper
MoC, nice job on the RMS documentation. Darned things can be finicky but you made it look easy.
86 CJ7, 258 Engine, T-177, Dana 300.
[url]http://www.jeepforum.com/forum/f8/let-games-begin-new-build-86-cj7-1046943/[/url]
A ton more pics here.
[URL="http://s1038.photobucket.com/albums/a462/E9Eaglekeeper/"]http://s1038.photobucket.com/albums/a462/E9Eaglekeeper/[/URL]
Eaglekeeper is offline   Reply With Quote Quick reply to this message
Unread 02-24-2011, 05:01 PM   #132
MoC
Big lesson I learned on that Jody, which I did not include, was not to use a wooden dowel. I read a post while researching that suggested it so that nothing would score the surface. What ended up happening was the dowel splintered and broke twice between the crank and the block. Spent about 20 extra minutes slowing turning the engine over by hand to get all the wooden splinters that were wedged out. PITA.
Unread 02-27-2011, 10:28 AM   #133
MoC
Well LSUtiger an I put in 2 1/2 hours of work yesterday and made a little progress.
Pulled out some of my new shiny parts.
New pilot bearing installed.
Spacer and flywheel installed. Ended up using my old flywheel bolts the Mr. Gasket replacements were to long for my comfort. They stuck out the flywheel and were a millimeter or two away from the engine.
Next clutch disk and pressure plate.
Assembled the bell housing fork, throw out bearing, and springs and installed it.
Tranny stabbed.
Cross member installed
Then lastly Tcase installed.
Only going to be able to get a hours or so in today and I am hoping to get both motor mounts replaced and the oil pan installed.
Unread 02-27-2011, 10:42 AM   #134
ChaseB
Wow that looks clean!! Nice!!
[B]1984 CJ-7[/B] Renegade
[B]2005 TJ X [/B](daily driver)
ChaseB is offline   Reply With Quote Quick reply to this message
Unread 02-27-2011, 11:18 AM   #135
Graffxman
1976 CJ7
That looks awesome! Is it now too pretty to drive???
Graffxman
'76 CJ7--304 V8
Graffxman is offline   Reply With Quote Quick reply to this message
