MoC's Build Thread - Page 54 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MoC's Build Thread
Unread 01-16-2012, 05:39 PM   #796
tractor1
1979 CJ5
It will be nice when you get it water tight and lights in!
1979 CJ5 304 T150 Dana 20 under construction
1993 Wrangler 4.0 HO AX15 231 4” lift 33 12.5 15 DD
1994 Wrangler 2.5 AX5 231 Stock Sold
1973 Cj5 304 T15 Dana20 Sold
[COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Black"][URL="http://groups.jeepforum.com/Built_Not_Bought"][COLOR="Black"]Built Not Bought #457[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
tractor1 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 10:05 PM   #797
Turtle71
1983 CJ7
Looks great! Good choice on the hardy board. Are you going to enclose the ends up top or maybe enclose them with plexiglass for natural light?
My 83 CJ7 Build:[url]http://www.jeepforum.com/forum/f8/turtle71s-83-cj7-project-1136836/[/url]
Turtle71 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 10:31 PM   #798
MoC
Going to close them up, I was knocking out all the full sheet stuff first since I had a friend helping.
MoC is offline   Reply With Quote Quick reply to this message
Unread 01-17-2012, 03:22 PM   #799
MoC
Early day so instead of working on the shed I did the only responsible thing to do... Worked on the jeep. Pulled the accelerator pump and found it cracked and that was my leak. Pulled a old one from another 2100 I have and installed it. Tightened it up with the 3 good screws and left the stripped one out. Started up runs good and no more leaks. Only problem is the one I swapped in apparently is to stiff and does not pump. Still runs fine so it will ride as is until the 360 goes in. Pretty day, partly clouded and 78 so drove around for a bit and hosed it off.
Unread 01-17-2012, 03:41 PM   #800
GlennLever
GlennLever's Avatar
Here is a neat idea for light during the day.
Watch the last half of the video, the first half drags.
Glenn R. Lever
Rochester, New York 14617-2012
My Cars http://www.leverfamilysite.com/vehicles.htm
My restoration thread here on the Jeep forum
http://www.jeepforum.com/forum/f8/cj...build-1269301/
New FED, Drag Racing Forum (I am an Administrator) at
http://www.frontenginedragsters.org/forum/index.php
GlennLever is offline   Reply With Quote Quick reply to this message
Unread 01-17-2012, 04:00 PM   #801
lucdog
lucdog's Avatar
1980 CJ5
Yea, MoC is back Jeepin.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 01-22-2012, 07:41 AM   #802
GlennLever
GlennLever's Avatar
http://www.youtube.com/watch?v=1umwv...eature=related
No comments on this?
I'd use it here but it would freeze. If I put antifreeze in it I would have green light in the shop.
Glenn R. Lever
Unread 01-22-2012, 10:03 AM   #803
MoC
Thats neat Glenn, missed it the first time you posted. Thinking about going with two circuits of can lights. No working this weekend, the wifey is working yesterday and today 7am-7pm so its a good daddy and kiddo weekend!
Unread 01-22-2012, 02:43 PM   #804
rixcj
rixcj's Avatar
1979 CJ5
That's a pretty clever, inexpensive idea, but I don't think I'd personally do that particular method on anything but a chicken coop or another similiar type of outbuilding. It's kind of hokey, plus I can imagine that the bottle would have to be changed out from time to time. That looks like it would not be a fun job.
I'd buy the real McCoy...
http://en.wikipedia.org/wiki/Light_tube
...and be done with it.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 01-22-2012, 03:10 PM   #805
GlennLever
GlennLever's Avatar
Rich
My understanding is the bottles lasts years, it is the caps that you have to watch. I'm told that if you coat them so the sun does not reach the cap they last years also.
Glenn R. Lever
Unread 01-29-2012, 06:09 PM   #806
MoC
Another day closer to getting back to the jeep..
Unread 01-29-2012, 06:13 PM   #807
243
1978 FSJ Cherokee
Where is the flashing between the old roof and the new siding?
It may be in place but the siding it looks like it is right on the asphalt shingles.
Edit: nevermind, I saw the flashing in an earlier photo.
It will look like this in a few years without more space between the siding and roof.
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 01-29-2012, 06:20 PM   #808
MoC
Flashing is there and the hardy board has about 3/4 between it and the flashing.
Unread 01-29-2012, 06:26 PM   #809
MoC
The picture is a little deceptive as well. The shingles are cut back about a inch off the wall. I am offically tired of the project as well....
Unread 01-29-2012, 06:31 PM   #810
243
1978 FSJ Cherokee
3/4" should be enough since the intersection is under the eave, and yes, the angle of the picture makes the siding look like it is on or behind the shingles.
Great job
BTW, it is time to germinate seeds
