MoC's Build Thread - Page 49 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MoC's Build Thread
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 12-19-2011, 07:27 PM   #721
ASteve
1972 CJ5
Originally Posted by MoC View Post
And all this started so I can store more jeep crap lol...
Ya gotta love it!
SC
[url]http://www.astevecali.com[/url]
ASteve is offline   Reply With Quote Quick reply to this message
Unread 12-19-2011, 07:36 PM   #722
GlennLever
GlennLever's Avatar
Your going to need a bigger air conditioner.
Glenn R. Lever
Rochester, New York 14617-2012
My Cars http://www.leverfamilysite.com/vehicles.htm
My restoration thread here on the Jeep forum
http://www.jeepforum.com/forum/f8/cj...build-1269301/
New FED, Drag Racing Forum (I am an Administrator) at
http://www.frontenginedragsters.org/forum/index.php
GlennLever is offline   Reply With Quote Quick reply to this message
Unread 12-19-2011, 09:54 PM   #723
lucdog
lucdog's Avatar
1980 CJ5
Whats the plan for the beam, LVL, steel, or 2x's?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 12-19-2011, 11:27 PM   #724
rixcj
rixcj's Avatar
1979 CJ5
Looks good MoC...it'll be worth it when you're done.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is online now   Reply With Quote Quick reply to this message
Unread 12-20-2011, 01:31 AM   #725
MoC
Thanks for the support guys. Tomorrow will be a big day if all goes well. Hoping to have the last 2 walls up, window and door in, and roof framed and decked the following day.
..and yes Glenn I will need a bigger a/c
MoC is offline   Reply With Quote Quick reply to this message
Unread 12-20-2011, 05:50 AM   #726
Skerr
MoC... go to bed!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 12-20-2011, 07:21 AM   #727
GlennLever
GlennLever's Avatar
How about the Pool?
Glenn R. Lever
Unread 12-20-2011, 07:45 AM   #728
MoC
Originally Posted by GlennLever View Post
How about the Pool?
lol if I had $40,000 to dump in to a pool there were be many others things I would do first. Parts washer will be the closet I come to a pool for a while.
Unread 12-20-2011, 09:56 AM   #729
Renegade82
Renegade82's Avatar
1982 CJ7
MoC, do you have residential building codes out there or is this too small and exempt? Just curious, I design homes for a living.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is online now   Reply With Quote Quick reply to this message
Unread 12-20-2011, 09:51 PM   #730
MoC
Well mother nature slowed us down today. It rained till about 1pm. Made the trip to Lowes and got all materials but the siding. That was a 3.5 hours job after getting the trailer, loading it at Lowe's, unloading it here, and returning it to the storage unit. Got the rear wall completely blown out and the beam built and up. The temporary jacks are still carrying the load until we finish installing the verticals on top of the beam up to the ridge and rafter. No rain in the future tomorrow so we will get a full day in. Pictures will come tomorrow.
We inspect off of the 2006 IRC. When Louisiana adopted the 06 IRC they did not adopt the admin section or the plumbing section. So we inspect off the 2000 LA State Plumbing Code and the admin section from title 43. The 06 IRC admin section says a AHJ can inspect over code but may not diminish code. By using the title 43 admin code it allows Louisiana AHJ's to diminish code as long as they do it uniformly. A example would be the requirement for fire caulking that should be installed in penetrations from the garage areas in to the living areas. You will never see that here.
This addition does require permitting because of the square footage. We have a 3 foot setback rule from the property line but in order to get the width I needed to make this work it I had to go closer than 3 feet to the fence line. The process to get that approved is a long road that goes through the MPC and zoning board. Talked to my neighbor on the other side of the fence and he was more than cool with it so I did not pull a permit. I was a little worried when the concrete truck was sitting up front but should be fine now since it is in the back yard and out of view.
Unread 12-20-2011, 09:53 PM   #731
MoC
Here is a teaser just for fun..
Unread 12-21-2011, 07:13 PM   #732
MoC
Got three and 1/2 walls up today. Did not snap a picture after the first two went up. Mother nature is going to dump a inch of rain on me tonight so had to raise everything off the floor of value in the shop. With all the bottom plates in it will hold water... :-(
Also got to meet tigerpaw today, he came and got a timing chain cover. Great guy, just wish I would have more time to talk jeeps but had to get back to work.
.and yes my fence is jacked up, was hoping to fix it before the addition but time did not allow.
Unread 12-21-2011, 08:36 PM   #733
Skerr
Termites be gone for the next 100 years! Good job MoC.
Kerrdog
Go Fish! <*////><
Unread 12-22-2011, 08:20 AM   #734
MoC
Rain sucks... Still raining, still not working, but on a good not most of the water flowed out the door rough opening and not through my shop.
Unread 12-22-2011, 10:40 AM   #735
GlennLever
GlennLever's Avatar
So, did you build it the length of the ark 300 cubits, its breadth 50 cubits, and its height 30 cubits?
Glenn R. Lever
