MoC's Build Thread - Page 122 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MoC's Build Thread
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-04-2013, 11:28 AM   #1816
GlennLever
GlennLever's Avatar
Originally Posted by MoC View Post
No worries Glenn, I am done with any serious Jeep work for a while and have to focus on house stuff. I dont mind any debate or comments here sir.
To help get back to Jeep stuff.
Current project is to put the stock stabilizer back on.
I have found three choices in the correct configuration and think I will go with the Monroe as it has the name recognition, I dislike the quality of Crown and Omix, and have never heard of KYB (shocks, not the jelly)
MONROE SC2940 Steering Damper/Steering Stabilizer
At 31.77
18040.01 Omix-ADA Steering Stabilizer JEEP CJ5 CJ6 CJ7 CJ8 55-86
39.25
KYB SS10316 Steering Damper/Steering Stabilizer
38.54
KYB is sold through Summit and I get a driver discount through them so Monroe and KYB are the same price to me.
Recommendations?
Glenn R. Lever
Rochester, New York 14617-2012
My Cars http://www.leverfamilysite.com/vehicles.htm
My restoration thread here on the Jeep forum
http://www.jeepforum.com/forum/f8/cj...build-1269301/
New FED, Drag Racing Forum (I am an Administrator) at
http://www.frontenginedragsters.org/forum/index.php
GlennLever is offline   Reply With Quote Quick reply to this message
Unread 06-04-2013, 11:53 AM   #1817
wm69
At 31.77
39.25
38.54
Recommendations?
Go to RockAuto. That Monroe is $23 there, KYB is $26.
5% discount code.....96788357969687
Never heard of KYB. I know Monroe Makes Rancho.
wm69 is offline   Reply With Quote Quick reply to this message
Unread 06-04-2013, 07:28 PM   #1818
Dadamsnv
1977 CJ5
KYB puts suspension on Kawasaki and suzuki dirt bikes if that helps. Or they did at least.
Cheers!
Dadamsnv is offline   Reply With Quote Quick reply to this message
Unread 06-04-2013, 07:58 PM   #1819
firemanjim7
1983 CJ7
Car quest carries them around here. Not a bad shock at all. Lifetime warranty.
firemanjim7 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 06:43 AM   #1820
gmakra
All shocks are made at Monroe or Gabriel and built for the particular vendor.
gmakra is online now   Reply With Quote Quick reply to this message
Unread 06-05-2013, 06:49 AM   #1821
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
And most all steering stabilizers have a 50/50 valving, so there's very little difference between any of them.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2013, 08:14 AM   #1822
CJ7ROB
Lots of women have switched to SUVs over the minivans anymore these days. My wife got a Durango in November. She loves it, mileage about the same as the Pilot, maybe a little less..alright no more jacking your thread Moc.
CJ7ROB is offline   Reply With Quote Quick reply to this message
Unread 06-07-2013, 09:31 AM   #1823
MoC
Going to put a little effort in to the jeep tomorrow. I am still fighting the front end issue. Last weekend I check air pressure and gave everything the eyeball and some pulls.
Locked and loaded now. Heading to a tire shop in the morning and I am going to try some air soft pellets.. Plan is to start at 10oz and go from there.
MoC is offline   Reply With Quote Quick reply to this message
Unread 06-07-2013, 02:44 PM   #1824
Jim1611
Jim1611's Avatar
Somebody starts a debate on your thread MoC that could have turned political and I wasn't here!!! Man I missed out. If I were to buy a brand new rig no way would it come from obama motors or the red headed stepchild brother Chrysler. I'd get one of those Toyota FJ Cruisers Okay, sorry for my scandalous attempt to highjack your thread and and cause trouble. I can't help it anymore, MoC
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 06-07-2013, 02:59 PM   #1825
scrapman
Originally Posted by PROJECT 23 View Post
"Never again a Ford..."
Never have and never will. I guess this would be the perfect time and place for this:
We had a man in a Chevy Suburban run through a 10 foot high fence and slam into guardrail we had surrounding a 250 gallon propane tank at my work. He had to be going 40-50 mph when he wrecked. While I was watching the wrecker pull the vehicle out, I commented to the paramedics that I noticed the Air Bag did not deploy. This was his reply word for word. "Yep, it's a Chevy. That is why all of us paramedics drive Fords".
scrapman is offline   Reply With Quote Quick reply to this message
Unread 06-08-2013, 11:07 AM   #1826
MoC
Back from Meineke. I am a little dumb as well. I thought the tires were bias but... turns out they are radials. First off, the air soft pellets did work well. Started off by pulling the weights and dropping in 10 oz of air soft pellets. With 10 oz the machine said it was still 7 oz out of balance to one side. Went back to the weights. Three tires balanced out perfect with a good amount of weight. The fourth tire, front pas, has a problem. Without any weights the machine calls for 30oz. Tried spinning the tire 180 on the rim and same result. Looks like I have a broken belt. Moved it to the rear. Drives great now, I hit 65 without any front end wobble. I can feel the bad tire a little in the rear, but it now drives better than it ever has. I use to start feeling a slight wobble around 60ish.
While it was on the rack with the tires off I did find some more problems. Fix on find 2 more. grr. One of my front hubs is not engaging and I have a rear outer axle seal seeping. I did stick the bad tire on the bad seal side of it so I didn't mess up the good one. I guess I will be buying a new tire and rim in the future. I need a spare so the bad one will still have some purpose.
Unread 06-08-2013, 12:26 PM   #1827
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
A several years ago I bought Pro Comp XTerrain tires. I could never keep them balanced and they took a lot of weight to balance. Last year I took it to the Ford dealer they have a road force balancer and told me the tires were defective. I guess the belts/cords were separating. I have since replaced them with BFG all terrains. The truck is now smooth going down the highway.
OrangeCJ-5 is offline   Reply With Quote Quick reply to this message
Unread 06-08-2013, 05:14 PM   #1828
Cutlass327
Cutlass327's Avatar
1978 CJ5
I didn't think you could balance a tire if it had dynamic weight inside. I don't picture the tire spinning long enough for the internal stiff to settle out.
Rick
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote Quick reply to this message
Unread 06-08-2013, 05:19 PM   #1829
MoC
I dont know.. He spun the tire up by hand then turned the balancer on. t spun around 15-20 seconds at high speed. I would imagine the bb's would have distributed out by then.
Unread 06-30-2013, 08:26 PM   #1830
MoC
Re torqued everything for the first time since my engine swap today. Cut off the pipe hangers that the muffler shop welded to my frame the first go around & trimmed up the skid "neater" where they had to cut it for the pipes. Got the areas primed and painted.
Gave her a good washing and did a little driving. Running great still
