MoC's Build Thread - Page 12 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MoC's Build Thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 03-05-2011, 07:12 PM   #166
Graffxman
1976 CJ7
Barnwell Mountain HERE WE COME!!!!
Graffxman
'76 CJ7--304 V8
Graffxman is offline   Reply With Quote Quick reply to this message
Unread 03-08-2011, 08:12 PM   #167
Skerr
I got Goosebumps Baby!! Now that you're in the game you can hold off the enemy while we continue to fix ours! Just... need... a... little... more... time!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 03-08-2011, 08:20 PM   #168
83vert
1982 CJ7
Great news Moc, enjoy it
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is online now   Reply With Quote Quick reply to this message
Unread 03-08-2011, 08:26 PM   #169
Capt_Drake
Capt_Drake's Avatar
CONGRATULATIONS!!!
My Clean Up / Refurbish Thread
Capt_Drake is offline   Reply With Quote Quick reply to this message
Unread 03-08-2011, 08:41 PM   #170
Graffxman
1976 CJ7
I got your back, bro. Collecting grill tools, charcoal, and ice for the coolers!!!
Graffxman
'76 CJ7--304 V8
Unread 03-08-2011, 08:57 PM   #171
MoC
Thanks guys! Put a few more miles on her sunday. If the weather plays nice tomorrow morning I am going to do some more work. I was tunning yesterday and noticed a spark plug wire moving. Shut her down and checked and sure enough 3 out of 6 were loose enough to turn by hand. Then the rain came. Anyway got me thinking that since she sat for 3 months of very cold weather that before I start her back up again would not be a bad idea to check and made sure everything is still nice and tight. Planning on checking valve cover and exhaust & intake bolts. Also since I have put a few miles on I am going to recheck oil pan, tranny, tcase etc and make sure it is all nice and tight. After than planning on putting my shocks back on and installing my new speedo cable. I still have the tunnel cover and shifter boots to install but have run in to a little problem that I need to address first. When I sprayed the underside with primer I did not seal the tunnel and some specks ended up in the interior floor. Soooo going to wait on putting the tunnel cover back on till I clean the interior floors and repaint over it. I painted all my interior tub back in june so its all pretty fresh still. Just going to paint the tunnel and floor pans black again.
MoC is offline   Reply With Quote Quick reply to this message
Unread 03-08-2011, 09:13 PM   #172
Davidnex
1979 CJ5
Great Job, getting me excited???
79 CJ 5 Frame up Build
http://www.jeepforum.com/forum/f8/79-cj-5-frame-up-1092681/
Davidnex is offline   Reply With Quote Quick reply to this message
Unread 03-08-2011, 11:00 PM   #173
VEX
1983 CJ7
Wow MoC, this thread and your work and the outcome is just killer cool. So rocks and I love it. This is awesome.
Don't shoot it, yet!
Robert
VEX is offline   Reply With Quote Quick reply to this message
Unread 03-09-2011, 05:41 AM   #174
243
1978 FSJ Cherokee
Where are the pictures?
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 03-09-2011, 08:00 AM   #175
Jeepican
1976 CJ5
Thats Awesome! .... im jealous!!!
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
[URL="http://www.jeepforum.com/forum/f8/slow-76-cj5-rebuild-1118617"][COLOR="blue"]My Build Thread[/COLOR][/URL]
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline   Reply With Quote Quick reply to this message
Unread 03-09-2011, 01:22 PM   #176
MoC
Pictures?? I dont post a whole lot of pictures Dave you must have me confused with Scott.
So this is all from last weekend. Inspection cover, shifters, starter, clutch linkage, and rear drive shaft installed. Spent some time getting the clutch free play dialed in as well.
Did not work today as long as I was planing ended up doing some driving instead. This morning installed the shocks, greased the rear drive shaft and bellcrank. Also checked and tightened bolts on valve cover, intake exhaust manifold, ubolts, ujoints, tranny, tcase, bellhouse, header to pipe conenctions, and starter.
I took her out for a 30 minute leg stretching today and she was happy the whole time. Spend about 8 minutes running 70 mph. Other my temp climbing from 190 to 200 as it always does going over 60ish all was well. As soon as I slowed down it went right back to 190.
So a little more about the oil leak I was talking about after my first drive. It has not gotten worse and does not actually drip on the ground. After my 30 drive this was all that was present. Part of the reason I wanted to hit 70 was to see it if would get worst and it did not.
Planing on pulling the inspection cover and looking inside but with it not dripping and only leaving this much I am almost thinking about letting it ride. Cant see pulling the oil pan again for this little amount. Based on what you see would you guys pull the pan or roll with it?
Unread 03-09-2011, 01:26 PM   #177
Capt_Drake
Capt_Drake's Avatar
No worries, it can only get worse.
Seriously though, I'd take the inspection cover off and figure out where it's coming from before it gets too dirty. That way when It does get worse, you know where it started.
Unread 03-09-2011, 01:43 PM   #178
MoC
Well it has to be either the RMS or the oil pan, both were replaced. I feel real good about the RMS job but when the 1 pc oil pan gasket and pan went up I had a feeling the gasket did not seat properly in the groove. If it is pooling in the bellhouse I am going to attach it fun sure.
Unread 03-09-2011, 01:54 PM   #179
Capt_Drake
Capt_Drake's Avatar
Thant should be a relatively easy fix
Unread 03-09-2011, 02:18 PM   #180
ChaseB
I'm hoping it isn't the RMS
My CJ is spewing it out from there lol. Be ashame to dirty up all that clean work you've done Moc!!
[B]1984 CJ-7[/B] Renegade
[B]2005 TJ X [/B](daily driver)
ChaseB is offline   Reply With Quote Quick reply to this message
