MoC's Build Thread - Page 101 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MoC's Build Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 02-04-2013, 07:26 AM   #1501
rixcj
rixcj's Avatar
1979 CJ5
You must have an old army cot, or a few blankets in your shop, don't you?
Ohhh, that's right, you probably don't have THAT key on there, either......
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 02-04-2013, 11:59 AM   #1502
Cutlass327
Cutlass327's Avatar
1978 CJ5
Note: put spare house key on spare car key ring
Rick
1978 CJ5 258/T177/D300, '86 D30/D44 WT axles, 'glass tub windshield frame, and fenders, 31x10.5 BFG A/T, TDK galv'd frame - DD and weekend toy
http://www.jeepforum.com/forum/f8/ri...8-cj5-1223197/
Cutlass327 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2013, 03:48 PM   #1503
Skerr
Skerr's Avatar
You're the man of the House! Tell her to hush up and get your breakfast cooked!!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 02-04-2013, 04:02 PM   #1504
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yeah, right....that would go over like a fart in church in my household.
My problem with tapping on the window is my wife has a loaded weapon in her nightstand, and she knows how to use it.
I've slept in my CJ before....
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2013, 06:30 PM   #1505
MoC
Originally Posted by 243 View Post
Dude!
Sleep in the car
I would rather suffer the wrath of Con!
Rich
No Army cot, some beer in the shop fridge and frozen corn dogs.
Did that today!
Yeah, easy for you to say BIG man. Lets see you run that one by Beth.
Matt
Loaded 9 by her side of the bed 45 by mine. I though about getting shot as well which is why I said baby several times while knocking. Jenn is somewhat trained and knows not to shoot till they enter the house. Also taught her dead men cant tell their side of the story so as long as they are inside.. Boom Boom Boom Boom Boom Boom Boom Boom Boom Click
MoC is offline   Reply With Quote Quick reply to this message
Unread 02-04-2013, 06:52 PM   #1506
MoC
Today was just one of those days. No inspections and was planning on working on the Jeep for at least 5 hours. I got lots of windshield time in tracking down parts but no wrenching.
I decided that since I was going through my wiring harnesses I might as well wire relays in to my headlights. After getting let in last night I spent some time reading up on hammers relay post and making a list.
Made stops at 3 different parts stores to get most of what I needed. Then to the junk yard to source some sealed relays with their mounting brackets and bases. Again following hammers advice I went straight to the Cadillac's. Decided since I was there might as well stock up. Paid $46 for this stash
Cadillac's are definitely the place to look. I also checked out 20 or so others and everything else I found had the relays inside the fuse boxes.
They are all Bosch relays. Decided that I am going to go with one of the 3 relay sets because they are sealed up completely vs the 4 relay sets. I am going to use 2 relays for the lights and it gives me room to expand. If I need more I can just slap another set in.
Here is what the others look like.
I have not decided on my finial install location but this is likely going to be it.
I also bought a 6 fuse block. Three will be for the headlight leaving me room for 3 additional circuits. One is going to be for my radio to clean that wiring up a little, again leaving me a little room to expand.
I wanted to install it below the the existing fuse block, but because of where the vin is located I will have to go lower.
Kind of worried that I will be kicking it with my foot. My 2nd choice is on the engine side of the firewall here.
Although its is not water proof I will not be getting water that high on my firewall. The humidity was another thought, but I cant imagine that it would be any less humid inside the jeep.
Any thoughts or comments on my placement ideas?
The final score of the day... As I was walking around I found my next project.
Family Bar for $100!!! I have been looking for about 6 months now and have not found anything close. Someone tried to remove it and stripped out most of the torx. I talked to the scrap yard guy and I can bring my generator in and cut it out. He said I can cut up the tub if needed. Kind of a shame since the tub is almost perfect, but it did come with square lights so who really cares. The jeep has been in the yard since july. This comes at a perfect time. The next project after all of this is tub body work, family bar install, paint the tub.
So all that lead to me then going home to fix the generator. The pull cord broke last time I used it. Hoping to go back for it in a few days.
Also got some Lowes time in. Made what I think is my last trip for misc bolts.
The only thing left I need to track down is something to use as a dedicated ground bus.
Unread 02-05-2013, 01:49 AM   #1507
mvigo
mvigo's Avatar
Your windshield time yielded a very productive day...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 02-05-2013, 11:44 AM   #1508
wm69
Might as well pull the YJ master cylinder and booster while you're in there.....I'm a manual brake guy but someonbody's always looking for YJ brakes......
wm69 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2013, 12:30 PM   #1509
MoC
I thought about it. I am running OffAgain Auto's Navjo brake so dont need it myself. A asked about prices on a few other things like it, grill, tailgate and they were looking for too much $ for it to make it worth while to pull.
Unread 02-06-2013, 10:39 AM   #1510
wm69
I tried a YJ setup. Pedal height was way off and I slapped another non pb setup on the Jeep while I lengthened the pushrod and ended up staying non-pb. I would only get it if you can resell for profit.
Unread 02-07-2013, 08:33 PM   #1511
bassfsr
Junior Member
1977 CJ7
Looks like we had the same idea!
bassfsr is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 09:54 PM   #1512
keith460
Jeep. There's Only One
keith460's Avatar
Hey bassfsr, who makes those seats in your Jeep? They are very close to looking like original design.
Nice looking CJ by the way!
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 11:21 PM   #1513
matthewleeblair
1983 CJ7
Dude... That whole bit of you getting locked out & everyone's comments had me cracking up. Needed a good laugh haha.
matthewleeblair is offline   Reply With Quote Quick reply to this message
Unread 02-08-2013, 12:55 AM   #1514
bassfsr
Junior Member
1977 CJ7
The guy I bought the Jeep from is an upholster. He did the seats just before I bought it. When I did the frame off, I just kept the seats as they were. They are out of a Chevy S-10 Blazer I believe.
Unread 02-08-2013, 12:49 PM   #1515
MoC
Nice looking 7!
Have not gotten much done recently. Got my relays mostly wired in but have been sick these last few days.
Made a junkyard run this morning and came back with everything I wanted.
- YJ family bar
- 3 ground bars
- 3 of the retractable lights
- 2 other lights that I just snagged that look like the factory cj ones
My generator fought me and I have to get all MacGyver in it. First the stupid pull cord spooler shattered. Took it apart and was able to spool the cord around a part and pull still. Then with only 2 roll bar bolts to cut it started stuttering and quit running. After a little looking found a fuel line that was cracked and sucking air. Pulled a line from a junk car and patched it back.
