MoC's Build Thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > MoC's Build Thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 12-01-2010, 09:30 PM   #1
MoC
MoC's Build Thread
Hey guys, over the next 3 weeks I am planning on rebuilding T176 tranny, replacing tcase seals, replacing u joints, replacing clutch and clutch hardware. This will be my first tranny rebuilt attempt and from what I have read here I think it is defiantly do able on my end. Also planning on painting tcase and tranny, drive shafts, and frame & tub area from engine back to gas tank. Using the Novak rebuilt kit. So its going to be a little project. So my first question is for the guys that have rebuilt the t176 how long did it you to just do the rebuilt from start to finish?
I will post pictures from start to finish along the way.
MoC is offline   Reply With Quote Quick reply to this message
Unread 12-02-2010, 12:19 AM   #2
Badshot
I just finished my 177, which is pretty much the same as the 176. Not really all that difficult. I took a picture of the top side when I got the shifter cover off to help me when I put it back together. Saved me a lot of trouble.
Badshot is offline   Reply With Quote Quick reply to this message
Unread 12-02-2010, 09:08 AM   #3
MoC
I have a spare 176 with a broken shaft to use as a referance. So how long did it take you do to the actual rebuilt portion. Not cleaning painting etc. just the rebuilt.
Unread 12-02-2010, 10:25 AM   #4
Eaglekeeper
Take a look at the pics on my build starting at #73 and the first few pages of Daves build http://www.jeepforum.com/forum/f8/da...-build-891652/. His build really helped me a lot, as did some PM's from yellow85cj.
It took me about 8 hours of actual work over a weekend, but my tranny was already out and on the bench. Lot easier than I thought it would be. Good luck.
86 CJ7, 258 Engine, T-177, Dana 300.
[url]http://www.jeepforum.com/forum/f8/let-games-begin-new-build-86-cj7-1046943/[/url]
A ton more pics here.
[URL="http://s1038.photobucket.com/albums/a462/E9Eaglekeeper/"]http://s1038.photobucket.com/albums/a462/E9Eaglekeeper/[/URL]
Eaglekeeper is offline   Reply With Quote Quick reply to this message
Unread 12-02-2010, 12:44 PM   #5
John Strenk
John Strenk's Avatar
1976 CJ5
Mine took about 3 months. 4 hours to tear it down, procrastinate a while, and 4 hours to put it back together.
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 12-04-2010, 01:19 PM   #6
MoC
Made some progress this morning. With some LSUTiger help we had everything down in about 1.5 hours. Took the tcase, tranny, and skid down as one. Came down easy. Tons of grease and oil everywhere. The fly wheel is worst off than I was hoping for. The ring gear has two bad spots, little bit small blue spots, and 2 scraps that are deep. Going to price out resurfacing it and replaceing the ring gear to see if it is just easier to get a clean replacement.
Unread 12-04-2010, 01:22 PM   #7
MoC
When it all came out found that part of the tranny mount was broken. Also was missing 4 bolts out of the bellhousing.
So thats it for this weekend. I am thinking next weekend I an going to degrease and clean frame and under the tub saturday. Then sunday prime and paint it tub underside and frame.
Unread 12-14-2010, 07:42 PM   #8
MoC
Made a little progress this weekend and today. Spent about 9 hours wire wheeling & degreasing and got the frame and under side of the tub cleaned up. Most of the underside was covered with 1/8 - 1/4 inch of crude from 24 years of leaks and abuse. Put a coat of white primer on everything and painted the pipes with black high temp paint. Next is a 2 coats of paintable rubberized coating and then 2 coats of gloss black. Tranny rebuilt kit will be here friday so I guess I will get on that next.
Unread 12-14-2010, 07:46 PM   #9
ChaseB
Wow, that looks incredible! I'm too lazy to do mine but these pics are motivation!!!
ChaseB is offline   Reply With Quote Quick reply to this message
Unread 12-14-2010, 08:08 PM   #10
MoC
Thanks Chase! It was so dirty that I have to throw away the pair of coveralls I worn to do it in. Know way if all that grease they were making it in to my washing machine. About 1/2 though I started getting real tired of doing it but the end product is worth it. Going to paint the bellhousing, tranny, and tcase gloss grey.
Unread 12-14-2010, 08:13 PM   #11
brownbagg
1930 MK Compass
why do people paint their tranny and transfer, the paint serve no purpose but waste of money.
brownbagg is offline   Reply With Quote Quick reply to this message
Unread 12-14-2010, 08:16 PM   #12
Trapshooter
MoC...WOW what a difference. Nice Job
Its amazing what a bunch of elbow grease will do. Keep the pics coming
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build: [url]http://www.jeepforum.com/forum/f8/trapshooters-401-build-1338277/[/url]
Trapshooter is offline   Reply With Quote Quick reply to this message
Unread 12-14-2010, 08:25 PM   #13
ChaseB
Knowing it looks nice even if no one else can see it
Peace of mind!
Unread 12-14-2010, 09:12 PM   #14
243
1978 FSJ Cherokee
It looks great!
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2010, 09:59 PM   #15
MoC
I am putting around $650 total in to this little project so the extra $10 -$15 dollars in paint it will cost me to do the tcase and tranny to make it all look nice is worth it to me even if it serves no other purpose.
