MoC's Build Thread - Page 26 - JeepForum.com
 3Likes
post #376 of 2044 Old 06-26-2011, 04:35 PM Thread Starter
MoC
Spent the morning and mid day cleaning the block, heads, and intake. Then put on two coats of primer.
Tonight planning on ordering AMC Blue Rattle Cans, valve cover gaskets, oil pan gaskets, timing cover gasket kit, choke stove gasket.
Going to let primer cure for 2 days, spray the intake aluminum wed, then next weekend spray the heads and block AMC blue. Also next weekend planing on cleaning up valve covers, oil pan, timing chain cover and starting to paint them
Hope everyone had a great weekend!! Happy with getting the engine pulled, broke down, cleaned, and primer. Feel like I was productive in the jeep department.
MoC is offline
post #377 of 2044 Old 06-26-2011, 06:31 PM
243
1978 FSJ Cherokee
It looks like a brand new motor
BTW, the pepper garden sucks this year
Dave's 78 Build
243 is offline
post #378 of 2044 Old 06-26-2011, 07:04 PM
Turtle71
1983 CJ7
Looking good! Looking forward to the rest. Did you decide about what color to paint the engine bay?
My 83 CJ7 Build:
Turtle71 is offline
post #379 of 2044 Old 06-26-2011, 07:45 PM Thread Starter
MoC
Thanks guys, cant wait to see it with the AMC blue and aluminum.
Have not Turtle...Going to be either my original color red garnet or black.
MoC is offline
post #380 of 2044 Old 06-26-2011, 07:53 PM
Shade00
1980 CJ5
Looks great! I can't believe no one wanted the Wagoneer. If I have the chutzpah and a place to work I'd try to build it. It looks like it has a good steering on it - is it a tilt column? That's worth a few bucks by itself.
Shade00 is offline
post #381 of 2044 Old 06-26-2011, 08:14 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by MoC View Post
Spent the morning and mid day cleaning the block, heads, and intake..
What was your specific procedure for cleaning those things? What chemicals and tools did you use?
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #382 of 2044 Old 06-26-2011, 08:38 PM Thread Starter
MoC
Yup auto tilt column, probably going to pull it once I unload it off the trailer at the scrap yard. I have to keep the tires and rims to, apparently they dont take the tires. They said after I unload it the will lift it up front end loader and I will have to pull the tires.
The engine only had a very small amount of oil in 2 areas on the intake. I used a wire wheel on my grinder for the large areas, wire wheel on my drill for the small areas, 4 cans of brake cleaner, and some shop towels. In the little nook areas on the intake I sprayed brake cleaner then pushed a shop towel in and used a screw driver to rub the towel around. Used my air compressor several time as I went along to blow the crap off. Sprayed the whole thing down with brake cleaner several times when I was done to help wash the left over crud away. When it was all said and done I then wiped it down with water.
I re torqued the accessible head bolts down and the intake bolts before painting it. I also used a palm sander with 220 grit on all the gasket surfaces (egr, choke stove, carb, etc.) before taping them off.
Still have everything else that attaches to the engine to paint. Going to clean most of it with a 5 gallon bucket with gas and a wire brush.
MoC is offline
post #383 of 2044 Old 06-27-2011, 10:22 AM
SonicR1
Man, two builds at once… I can't even get one done… hehehehe they are looking real good Mo!!!!
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #384 of 2044 Old 06-27-2011, 10:35 AM
scrapman
Next weekend my TOP #1 BIG PRIORITY is to bring this to the scrap yard. $100 bucks a ton.
Are you sure on that $100 per ton? We are paying $200 per net ton ($10 per hundred) for auto bodies in Tyler. Shreveport should be somewhere close to that.
scrapman is offline
post #385 of 2044 Old 06-27-2011, 10:40 AM
benullman
1981 CJ7
Its the same out here. .10 a lb, $10 100lb, $200 a ton
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #386 of 2044 Old 06-27-2011, 10:54 AM Thread Starter
MoC
Thats what I was quoted at the first place I called. Guess I need to try a few others or maybe drive to Tyler. Thanks for the heads up.
MoC is offline
post #387 of 2044 Old 06-27-2011, 10:55 AM Thread Starter
MoC
Just one build, the 360 is going in the CJ. The waggy was just the donor.
MoC is offline
post #388 of 2044 Old 06-27-2011, 10:58 AM
Shade00
1980 CJ5
I guess that Wagoneer's got a TF727, right? Wish it were a TF999. I've been wanting a little auto to put in my CJ5, but the 727 has issues with pan clearance on stock suspension.
Shade00 is offline
post #389 of 2044 Old 06-27-2011, 10:59 AM
Eaglekeeper
MoC, motor cleaned up nice and is going to look great.
86 CJ7, 258 Engine, T-177, Dana 300.
A ton more pics here.
Eaglekeeper is offline
post #390 of 2044 Old 06-27-2011, 11:24 AM
VACJ7
VACJ7's Avatar
Looks great MoC! Love a fresh coat of primer and paint. You might want to call a local transmission shop and see if they want to buy the transmission as a core. Then again, might not be worth the trouble.
VACJ7 is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
