MoC's Build Thread - Page 13 - JeepForum.com
 3Likes
post #181 of 2044 Old 03-09-2011, 01:41 PM
VEX
1983 CJ7
Fabulous photo montage, MoC. Well done and so good to see the actual mods and addons and work. You're gonna love NM.........ha!
more, more, more,
Robert
VEX is offline
post #182 of 2044 Old 03-09-2011, 04:36 PM Thread Starter
MoC
Originally Posted by Capt_Drake View Post
Thant should be a relatively easy fix
Well easy yes but 2.5 - 3 hours of work to support the bell house, pull the passenger motor mount, pull the pan, clean and put it all back up.
Originally Posted by ChaseB View Post
I'm hoping it isn't the RMS
My CJ is spewing it out from there lol. Be ashame to dirty up all that clean work you've done Moc!!
Yeah I am 100% for sure not going to let it dirty up my work. It is soooo small and does not drip that I am not worried about that yet. Guess I just need to pull the inspection cover and see if its pooling or not. If so I am going to pull it if not I might let it ride for a bit. After 3 months of being down I am ready for a break on working on that.
I am thinking its about time to pull the hardtop as well so I might do that this weekend. I also really need to do a good wash inside and out.
Lets see, also parts I currently have to install.... new speedo cable, defroster light which is damaged, new head light, ash tray, new lighter, knee duct, new plastic glove box. Also want to touch up a few scratches from installation. I guess it never stops......
MoC is offline
post #183 of 2044 Old 03-09-2011, 04:50 PM
ChaseB
I hear you on wanting to drive it, that's where I'm at with mine! So much that needs to be done but it's time I actually enjoy it, if not I may go Charlie Sheen!!
Pulling the ole heater core tomorrow, after that just add a couple quarts of oil every now and then haha
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #184 of 2044 Old 03-09-2011, 05:21 PM
Jim1611
Jim1611's Avatar
Things are looking great there MoC. I think I'd take a look at what's under the cover too. That may very well be all you see for a long time. You've done some nice work on your CJ!
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #185 of 2044 Old 03-10-2011, 05:29 PM Thread Starter
MoC
Well had a little play time today..
Installed new speedo cable, new tcase vent line, new fan and defroster indicator lamps, replaced two burnt out speedo lights. Also my defroster pull knob was loose so I JB welded it to the pull cable. Next I was going to pull the inspection cover to see if there was any oil pooling from my tiney tinny little oil seep. But that did not seem as much fun as messing with my hubs. Pretty happy with how they turned out.
Pulled them apart and cleaned them. Coat of primer, 2 coats silver, 2 coats blue, 3 coats clear on top.
MoC is offline
post #186 of 2044 Old 03-10-2011, 05:33 PM
mvigo
mvigo's Avatar
those look fantastic!!
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #187 of 2044 Old 03-10-2011, 05:36 PM
caseman580
1976 CJ7
Hubs look good. That there inspired me to do mine.
1976 CJ7, 304, quadratrac, TH400,
"Real Jeeps have flat fenders for your tools"
caseman580 is offline
post #188 of 2044 Old 03-10-2011, 05:43 PM Thread Starter
MoC
After I primed and painted the silver I also put 2 coats of clear on before the blue. I had the blue left over from my oil pan. I sprayed the blue in to a spray can top and used a brush to paint the blue inside the hub. After each coat of blue I sprayed a little brake cleaner on a clean rag to wipe off the little bits of blue over brush from on top of the hub on the silver surface. With the clear on it wiped right off and did not smear it in with the silver.
MoC is offline
post #189 of 2044 Old 03-10-2011, 05:59 PM
mvigo
mvigo's Avatar
you need to change your avatar to something more appropriate...
mvigo is offline
post #190 of 2044 Old 03-10-2011, 06:20 PM Thread Starter
MoC
You dont like? I think it represents the love / hate relationship my CJ and I have.
MoC is offline
post #191 of 2044 Old 03-10-2011, 06:25 PM
mvigo
mvigo's Avatar
I liked it very much right up to the point where you put everything back together (beautifully I might add) and got her running...I have sensed nothing but love from you and your CJ since page 11 post #157!!
mvigo is offline
post #192 of 2044 Old 03-10-2011, 06:37 PM Thread Starter
MoC
Well I guess your right about that.... Ha.. Just had a idea.. Will change it tommorow when the sun is back up for a new picture.. Stay tuned...
MoC is offline
post #193 of 2044 Old 03-10-2011, 07:54 PM
VEX
1983 CJ7
I absolutely love your avatar and it is perfect. I just replace your hand shooter with my 12 gauge, a few times aimed at VEX's face when he f__ks up as he often does for no apparent reason. I also threaten VEX that he will be reduced and remade into a Honda Civic. He pulls himself together shortly thereafter, sobered, visibly shaken.
Good!
I love it!!
Robert
VEX is offline
post #194 of 2044 Old 03-10-2011, 07:58 PM
243
1978 FSJ Cherokee
The hubs look brand new, great job!
Dave's 78 Build
243 is offline
post #195 of 2044 Old 03-10-2011, 08:02 PM Thread Starter
MoC
Thanks Dave!
MoC is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
