MoC's Build Thread - Page 123 - JeepForum.com
 3Likes
post #1831 of 2044 Old 06-30-2013, 07:32 PM
243
1978 FSJ Cherokee
Nice job on the windows!
Have you finished the inside of the house?
Dave's 78 Build
243 is offline
post #1832 of 2044 Old 07-01-2013, 10:25 AM
wm69
Originally Posted by MoC View Post
Apparently my crap azz mechanic nicked the power steering hi pressure line when doing the 360 installed. I actually saw it when it happened but was thinking it was so small no way it would leak. Well turns out it started leaking. Replaced it today, cursing myself the whole time with how much easier it would have been to do a few months ago when the engine was out. Going to take a home work break this weekend and put a few more hours in to the jeep on Sunday re torquing everything from the engine swap and few other small things.
I can relate. I nicked the power line going to my shop with my hedge trimmers a couple weeks ago. 1/2 the power in my shop doesnt' work now.
I said the same thing..."that little nick didn't hurt anything"
5 seconds of not paying attention's gonna cost me a couple of hours or running a new line from junction box to breaker box.
wm69 is offline
post #1833 of 2044 Old 07-01-2013, 11:31 AM
83vert
1982 CJ7
Hey Moc I'm not sure if you painted your rims black or they came that way? If you painted them what did you use?
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #1834 of 2044 Old 07-06-2013, 06:05 PM
mvigo
mvigo's Avatar
MoC, I PM'd you about lockouts, do you have any?
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #1835 of 2044 Old 07-06-2013, 07:47 PM Thread Starter
MoC
:-) returned
MoC is offline
post #1836 of 2044 Old 07-08-2013, 11:52 AM
wm69
I dont know.. He spun the tire up by hand then turned the balancer on. t spun around 15-20 seconds at high speed. I would imagine the bb's would have distributed out by then.
You happy with the beads? Got my 31" BFG AT's moved over to some OEM chrome wagons this morning. Couple of them have 5-6 wheel weights on the outer rim. Kinda BLAH after all the work I did cleaning up that chrome!
wm69 is offline
post #1837 of 2044 Old 07-08-2013, 01:30 PM
OrangeCJ-5
1978 CJ5
5-6 wheel weights? Hope none are 180 out from each other.
OrangeCJ-5 is offline
post #1838 of 2044 Old 07-09-2013, 09:04 AM
wm69
I'll check, but don't think they are. What is the significance of weights 180 deg from one another?
wm69 is offline
post #1839 of 2044 Old 07-09-2013, 03:00 PM
OrangeCJ-5
1978 CJ5
Nothing other than one weight is counter acting the other i.e. poor job done balancing the tire
post #1840 of 2044 Old 07-09-2013, 04:14 PM Thread Starter
MoC
I stuck with weights, I could not get them to balance out with the beads.
MoC is offline
post #1841 of 2044 Old 07-09-2013, 04:19 PM Thread Starter
MoC
Parking the 86 for a short while. My oil pressure has been low after the 360 install. Once it has really really warmed up I was getting around 8-9 psi at idle. After driving around in the heat at 55mph today it started reading down to 6.5 - 7 psi. Ordered a pump rebuild kit and mid plate from BJ's today, hoping it does the trick. We leave on vacation in 13 days for 2 weeks to Colorado and I might not have time to get it done till I return.
MoC is offline
post #1842 of 2044 Old 07-10-2013, 06:43 PM
OrangeCJ-5
1978 CJ5
Has it dropped a lot from the initial start up? How does the oil look?
post #1843 of 2044 Old 07-10-2013, 07:06 PM Thread Starter
MoC
Oil looks fine. The cover was worn when it went back together and I was worried about it then. I should have replaced it then. It's has not dropped more that around 2 psi.
Hoping the mid plate will do the trick.
MoC is offline
post #1844 of 2044 Old 07-10-2013, 10:17 PM
Skerr
Only 12 days to go. The countdown has begun.
wm69... I would suggest the reason you have so many weights on a wheel is that it's warped. Pretty common problem with welded steel wheels. Sometimes it is bad enough they have to be replaced right out of the box.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #1845 of 2044 Old 07-12-2013, 09:56 AM
wm69
Might be. I haven't even driven the Jeep since I had the tires mounted. It sure looks good though!
wm69 is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 06:54 AM
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 06:10 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 01:05 PM
