MoC's Build Thread - Page 115 - JeepForum.com
 3Likes
post #1711 of 2044 Old 04-16-2013, 10:50 PM
WNC-84CJ7
Hey MoC-
Don't know how far you roam, but I thought of you when I saw this.
http://knoxville.craigslist.org/cto/3702411451.html
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline
post #1712 of 2044 Old 04-16-2013, 11:11 PM Thread Starter
MoC
Originally Posted by WNC-84CJ7 View Post
Hey MoC-
Thanks for looking out! Knoxville is around 11 hours so its a little tooooooo far. Its a good price for what it is and would be tempting if it were closer.
Just got back from my everyone is sleeping so I went on a jeep ride ride. Pretty night.
MoC is offline
post #1713 of 2044 Old 04-27-2013, 07:44 AM Thread Starter
MoC
Off to the exhaust shop to get the rear of my pipes reworked..
MoC is offline
post #1714 of 2044 Old 04-27-2013, 08:58 AM
Skerr
Originally Posted by MoC View Post
I could drive past your house and kill your whole front lawn! My lip is STILL dragging since the oil leaks started.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #1715 of 2044 Old 04-27-2013, 09:04 AM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
Have sawzall, will travel! That quote could so be taken out of context. I listen to too much Lex N Terry on the radio in the morning.
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #1716 of 2044 Old 04-27-2013, 05:44 PM Thread Starter
MoC
Exhaust re routed. I ending up going straight out the back with turn downs. I gave up on the side exit because I didn't want to have to do it again if I stick a rear bumper on. I still have to pull the old hangers off the frame. Went back with hangers bolted through the baffles.
Also had the alignment checked. Toe was out to open.
Drive around and no fumes in through the back. I also developed a bad front end wobble early this week. Fixing the toe actually made it worst. Guess I will dig in to that soon enough...
image-3145224990.jpg   image-2221640687.jpg   image-1874623987.jpg   image-3297958383.jpg   image-2506870095.jpg
MoC is offline
post #1717 of 2044 Old 04-27-2013, 05:55 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Are the ball joints tight? It looks like you're running some pretty big rubber....
Matt
Matt1981CJ7 is online now
post #1718 of 2044 Old 04-28-2013, 01:15 AM Thread Starter
MoC
Matt
I have not had time to track it down yet. I spend this afternoon and spending tomorrow doing housework and shop clean up. My sons birthday is coming up in a few weekends and I have been told to get the shop area back under control.
Its in the front drivers side for sure. Feels to me like it might be a wheel bearing but we shall see. It kicks in when I am driving at a constent speed at around 35 or above. It starts to vibrate bad like death wobble. I can look out and see the drivers front wobbling. If I mash the gas and speed up quickly it smooths out.
MoC is offline
post #1719 of 2044 Old 04-28-2013, 01:37 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
Sounds like ya got it licked!
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #1720 of 2044 Old 04-28-2013, 03:24 AM
gazzo
Funny
Gary (gazzo)
http://www.jeepforum.com/forum/f8/gazzos-cj10-truck-2185617/
gazzo is offline
post #1721 of 2044 Old 04-28-2013, 07:25 AM
GlennLever
GlennLever's Avatar
I like the new exhaust set up. I did not like the hanger welded to the frame.
Do you have a stabilizing shock on the tie rod?
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #1722 of 2044 Old 05-03-2013, 01:48 PM
Skerr
Throw a weight?? I would say mud on the inside of your rim, but it ain't durty!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #1723 of 2044 Old 05-03-2013, 03:09 PM
scrapman
Check for out of round tires. Raise up the front end, and spin the tires checking for roundness.
My daughter's car had a terrible steering wheel shake at around 40-50. I took it to a trusted shop, and he aligned it, turned the rotors, balanced the tires, and told me my tires were out of round. So off to the tire store I went. The tire store re-balanced them, and told me the tires were not bad, but the first shop had balanced them wrong. (they were pirelli tires and only about 6 months old, and less than 3000 miles on them) Still had the shake.
Totally frustrated, I took matters into my own hands. I jacked up the car, and put it in gear (front wheel drive). Both front tires were visibly out of round by a lot. The rear tires were also, but not as bad. Went back to the store with my new found knowledge, and they warranteed the tires.
Moral: If you have a shimmy or shake you can't track down, look for out of round tires.
scrapman is offline
post #1724 of 2044 Old 05-03-2013, 03:56 PM
Dadamsnv
1977 CJ5
He speaks the truth! I have the same issue with my CJ right now. I can no longer drive it on the freeway because the tires are getting worse, but I can't find a good used set and I can't afford a new set, so it's surface streets for me
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #1725 of 2044 Old 05-03-2013, 05:16 PM
lucdog
1980 CJ5
When I had 35/12.50/15's in stalled on the turbin rims I bought a number of years ago. The SAM's guy said one of them wouldn't balance . I told him to break the bead and rotate the tire on the rim 180, ( research paid off here) guess what, 3 oz. and it was balanced.
If I were on a tight budget I would google "air soft pellets in tires" you may find a formula for the correct amount. These work, I personally know 4 people who use them. I have them in bias ply interco LTB's 33/13.50's . They work.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
86 CJ Build Thread JimNut Jeep CJ Forum 18 07-03-2012 07:54 AM
19?? CJ7 build thread biker250 Jeep CJ Forum 96 12-27-2010 07:10 AM
Build Thread for my '84 CJ erik5387 Jeep CJ Forum 19 05-29-2008 02:05 PM
